Question about Canon PIXMA MP130 All-In-One InkJet Printer
Not printing LCD display says CANCELLING - will not respond to any other keys or print requests
  • Anonymous Aug 24, 2008
    canon pixma mp130 all in one
    Problem Solver:
  • 18 Answers
Service mode operation procedures *
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the StoplReset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop 1 Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the StoplReset button the specified number of time(s) according to the function listed in the table below.(Each time the StoplReset button is pressed', the LED lights alternately in orange and green, starting with orange.)
3 times
Oranqe
EEPROM reset
Posted on Sep 18, 2008
How do I cancel a print request?
If you are using a current Windows operating system, you should see a printer icon at the bottom right corner when you have a pending print job. If so, click on it to open the print manager and view pending print jobs. You should then be able to select the "stuck" print request and choose the option to cancel it. If your situation is similar to mine at the office, it can take several moments for the queue to actually clear.
Sep 08, 2017 | Office Equipment & Supplies
Says disconnected but it isn't
I have put together a couple off guides for troubleshooting different offline printer issues for Windows XP, Vista and 7. I would recommend checking them out here: http://www.refreshcartridges.co.uk/igloo/how-to-make-your-offline-printer-online/
Hope they help.
Apr 12, 2013 | HP Photosmart C6280 Printer
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
JAM LABEL
1. Turn the printer on and make sure that the LCD display reads 'ON LINE'.
2. Press the PAUSE key once. [The display will read 'PAUSE'.]
3. Press and hold the PAUSE key until four or five labels feed forward.
NOTE: On some models, pressing the pause key will change the LCD display to 'TRANSMISSIVE'. If this happens, repeat step 3.
4. Press the RESTART key. The printer will go back ON LINE.
5. Open the print head and reposition your labels, so that they are ready for printing. Close the print head.
Nov 17, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Won't print word document- registers as qued to print, but doesn't print
I have one of these myself and often have the same problem when the printer is overloaded with requests.
You can try cancelling all print jobs in the print que and then selesting print.
Or if that doesn't work, just unplug the USB cable in the back, wait a few seconds and plug back in ready to start from scratch. This works every time for me.
Feb 01, 2010 | HP DeskJet F380 All-In-One Printer
Have a print job in the printer that i want to cancel. have unplugged the machine from the network, unplugged the machine from power. when i turn power back on, it start printing 500 page job that i do not...
Press the [PRINT MONITOR] key in the lower right corner of display. If fascimile option is also installed, it would say [SYSTEM MONITOR] key in same location. Anyways, after in print monitor screen, select the job that you want to cancel and press [CANCEL] key. Press [YES] to cancel. Press [DONE]. You might want to pull out all of the paper trays so the machine can't print while cancelling documents. Let me know.
Nov 02, 2009 | Canon ImageRUNNER 330s Copier
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
My canon mp210 is not responding to printing requests. we have replaced both colour cartridges. note: printer will photocopy a page, but again, it will not respond to request to print a word document, for...
Is there any blinking of light when the print command given. Any error message at printer display or Computer Screen ?
There is some problem in printing options. Please check and make default setting in the Printer properties. Go to Control Panel --> Select the printer --> Open printer window --> properties --> make them defauls --
During print command check whether the spooling in printer window goes completely or not (if it stop in middle )
Let me know in brief to solve this problem before going to reinstall printer drivers and do not vote till you recieve a good solution for this problem.
Nov 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
ZEBRA Z4M PRINT QUE ERROR
Try a reset: press the PAUSE and FEED keys while turning the printer, release the keys when feed the label. You can also try downloading the latest firmware.
Jul 02, 2008 | Zebra Z4M Printer
Printer gets stuck with a "Printing ..." or "PC Print ..." message on the LCD display
I have the same problem with mine. Another option is to "Log Off Administrator" at the PC or "Restart" the PC and prior to shutting down it seems to pfrint all my jobs ... better than cancelling.
Jan 26, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
