Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Electrical Problem with my fatboy
I layed my 1998 fatboy there is no body damage exept for my crash bars.
Now my speedometer does not work also my turn signals do not work and my horn does not work could this be one problem or multi problems.
Please Help
BRAD
  • fatboy2471 Aug 28, 2008
    Continued from: Electrical Problem with My 98 Fatboy
    I replaced one relay underneath the seat, but the bike still has the same problems consisting of no speedometer, no brakelights, no horn, and no blinkers. Also I found a ground wire that was broken and I fixed that. In addition, whenever I turn the bike on to ignition position, I here a clicking noise come from one of the fuses. However, when I tested the fuses with a TEST LIGHT they were fine.
    Thank you,
    Brad
    Genius:
  • 2,028 Answers
If you have the electric speedo, then it's one problem. There is a relay that all three of these go through in order to work. I'll bet you popped the relay. I don't know exactly where the relay is, but your local dealer can give you the location. If you have the manual speedo, the it's two probs. First, the cable to the speedo gear on the front hub has most likely pulled out a bit, and second, the same relay as before, only the speedo isn't routed through it.
Posted on Aug 22, 2008
  • Ryan Rogers
    Ryan Rogers Aug 28, 2008
    Is there a bare wire around the fuse that is causing the clicking? If not, I would go ahead and replace it, just to be safe. Also, does this have the electric speedo?
    This still sounds like a relay problem, but it's odd that you can't find it. You might try taking a look inside the hand controls, it could also be that a wire has come loose or a switch is hung up and canceling everything out.
How do you replace the speedometer cable in a 1998 chevy tracker
Removal Procedure
  1. Remove the instrument cluster assembly. Refer to Instrument Cluster Replacement .
  2. Unhook the speedometer cable from the heater case.
  3. Remove the grommet from the bulkhead.
  4. Feed the speedometer cable through the bulkhead.
  5. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Unscrew the speedometer cable (1) from either the transfer case or the transmission. Remove the speedometer cable (1) from either the transfer case or the transmission. Remove the speedometer cable (1) from the clamp. Remove the speedometer cable (1) from the vehicle.
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable. Remove the hazard lamps switch by gently pulling the knob straight up. Remove the instrument cluster bezel from the instrument panel. Refer to Instrument Panel Cluster Trim Plate Bezel Replacement . Remove the 4 screws and pull the instrument cluster assembly forward from the instrument panel. Disconnect the 3 electrical connectors. Remove the speedometer cable at the speedometer head. Remove the instrument cluster assembly from the vehicle.
Remove the 5 screws (2) and the steering column upper and lower covers (1, 3).
Remove the 4 screws and the instrument cluster bezel from the vehicle.
Jun 17, 2015 | 1998 Chevrolet Tracker
The speedometer does not work
On older cars there was a cable that ran to the speedometer and it was often necessary to replace the cable. Newer cars are electronic and part of the computer body module computer. According to Buzzle.com: " Cars produced after 1990 are usually equipped with speed sensors, which may crash and cease to transmit speed readings to the speedometer. A more serious problem could be a faulty speedometer head, which needs expert diagnosis.
Read more at Buzzle: http://www.buzzle.com/articles/speedometer-not-working-properly.html " You will find the speed sensor behind the engine, above the trans-axle.
Remove the connecting hose, air cleaner and electrical connector from above the sensor.
With help of a 10 mm socket, remove bolts keeping the sensor in place. Then, twist the sensor to take it out.
Attach a new O-ring to the sensor and clean the sensor flange and exterior sensor housing before re-installation.
Fix the new sensor in place and tighten bolts around it. Reattach the hose, air cleaner and electrical connector on to the sensor.
Read more at Buzzle: http://www.buzzle.com/articles/speedometer-not-working-properly.html" I hope this helps.
Apr 26, 2015 | Cars & Trucks
Why after I replaced throttle grip on harley fatboy and now the brake light stays on and speedometer doesn't work. How to fix?
What year??? You probably did not place the spacer under the brake lever when you took things apart and damaged the brake switch. I do not know about your speedo. What codes are displsyed.
Apr 26, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
How do I install rear crash bars on my 02 fatboy
Hi Hawaiisfines, for more information on your question please visit the websites below and good luck:
Install Saddlebag Guard Crash Bars on Harley Davidson Biker Motorcycle...
Nov 21, 2011 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
After laying my bike down the speedometer stopped working the key symbol on the speedometer stays lit up and the turn signals stay lit constantly and when I turn the turn signals on they don't blink. Where...
Do you have the security system on your Dyna? What side of the bike hit the ground? I would start by looking at any obvious areas that received damage.
Does the engine start and run, or does it try to start, but won't keep running?
If you have the security system, it may need to be put on the computer at the H-D shop and be reprogramed. If the bike hit the ground hard, the module may need replaced.
If you received damage to the controls on the handle bars, I would check for wiring damage in that area.
Everything you mention as not working is electrical, and, if you have the security system, it all runs through there.
I find that the owners manual helps some, but sometimes it takes a phone call to a shop.
Apr 10, 2011 | 2004 Harley Davidson FXD - FXDI Dyna Super...
I need a crash bar for my 2002 fatboy will any softail one work ???
I really can't answer that question. Go to this site and check the # for a 2002 bar and compare it to other year models. http://www.customchrome.com/dcm/cc/view.asp?ccataloghm.html
Mar 16, 2011 | Harley Davidson FLSTF - FLSTFI Fat Boy...
How do I remove the side luggage carriers?
Lay a piece of carpet on the ground on the right side of the bike. Lay the bike over on the "crash bars" on the right side. Best if the fuel tank is not full. Remove tire.
Apr 14, 2010 | 2008 Honda GL 1800 Gold wing Deluxe
I have a bicycle speedometer 15 function bell model 111741 that has stoped running. I might have crashed into a tree and it has not worked since there is no damage apparent to the instrument I replaced the...
Assuming that the display is working, have you tried adjusting the sensor or magnet so that they are close together? This model doesn't have a very good reputation for lasting based on online reviews. Good luck!
Mar 06, 2010 | Bell Cocoon Child Carrier
Speedometer/odometer stopped working today (panel not displaying any data). where do i start?
Always start with the easy stuff first on electrical- fuse panel first.
Sep 04, 2009 | 1998 Cadillac DeVille
Lands Phones Logo
314 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
