Question about Canon PowerShot A560 Digital Camera
Lens error, restart camera
Can you explain a little more detailed how and where you stuck the paperclip or fork.
im just really confused
  • 47 Answers
Well, for one, there's no guarantee that this will work for all people with this problem, it just happened that I lucked out since I know there was no damage to my camera and it was only 3 weeks old. But I was sitting at my desk and decided to give it a shot with one of the tines on a fork.
All I did was pull the shutter over the lens apart with my fingers and place the tine of the fork in the bottom right corner between the rim of the shutter and the outer rim of the lens. Then, as I powered the camera on I just pulled until the lens extended - which did require some force, but not much (it's likely the camera could get more damaged by the amount of force necessary - so it's 50/50).
Of course it was stuck in the extended position for a moment, but I simply turned the camera off and back on again and now all is well. I've been using the camera just fine with no issue ever since. Hope this helps. Good luck.
Posted on Aug 22, 2008
Lens Error
If you are sure that your battery is fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 11, 2009 | Canon PowerShot A550 Digital Camera
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Sep 13, 2009 | Canon PowerShot A470 Digital Camera
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
First of all, make sure your batteries are fully charged.
If it's still stuck, you could try hold the lens with two fingers, and when you turn the camera on, you **** the lens around just a little bit. Do not use a lot of force, just slightly **** it around. That might unfreeze it.
If that won't help, I'm afraid you're going to have to bring it to a camera workshop.
/Chris
Jan 19, 2009 | Cameras
Lens error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Jan 03, 2009 | Cameras
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2008 | Canon IXY 1000 Digital Camera
K850i
The easiest way to take pics with the SE K810i, I just slide the lens cover and it auotmatically goes to camera mode
Jan 06, 2008 | Sony Ericsson W850i Cellular Phone
Lens Error, Restart
That Was So helpfull i thought i had to buy a new camera until i tried that thank you so much
Oct 26, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot A560 Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
