Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire gallaxy front load washer
Door error code is on, machine can not begin cycle bc the door won't lock closed
  • 876 Answers
Have you tried a simple reset? turning it off, unplugging it for a few minutes and plugging it back in?
Posted on Aug 21, 2008
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Won´t spin at all in any cycle
Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
Aug 05, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer wont do the spin cycle. everything else work fine but no spin
The reason the washer won’t spin is due to the either of the latches on the door.
On the entire Frigidaire ATFxxxxxxx line of front load washers, if the secondary door lock fails, the unit will not spin. If you suspect this is the reason your washer is not spinning, do a check of the error log and you will find an E47 error has been logged. This error indicates the control board thinks the wax motor has failed because the auxiliary switch never closed. The customer will not see this error in the display, but it will be stored in memory. A quick resistance check of the wax motor will tell you if it has failed. Expect 1K to 1.5K of resistance from most of the wax motor heaters.
After finding the E47 error stored in memory, I would request you that the switch be removed from the outer door seal spring so you could pull the switch out the front. A quick resistance check showed the wax motor was open electrically so it was no longer working. Install a new switch assembly
, reattached all the wires along with the door seal. And now the washer will wash and spin.
Thank You for using Fixya.com
Jul 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error Codes
Door Open. if it does this when running or door closed, probably the door lock asm. also check latch on door, this plastic wears and breaks
Feb 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load washer stops and starts and door lock light remains on
You probably have a bad door latch or door interlock. Both, if defective will cause the symptoms you describe. The door must remain closed and lock before a wash cycle will begin, and for it to complete properly.
Jul 10, 2007 | Frigidaire FWTBB30DS Front Load Washer
Washer won't start a cycle
it means the door lock is open, unplug the washer and it should reset the lock it did for mine when i got the code
Apr 22, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
