Question about Panasonic Televison & Video
I have an old cinema vision projection system model pyh-3778r given to me and it worked when i picked it up but now that i got it home i plugged it in and no picture just some sound. help please!
    Genius:
  • 2,920 Answers
Alot of times when you move older tvs you end up jarring things around so it wont work as it should,,,youll find you have something loose somewhere inside the tv
Posted on Aug 21, 2008
SOURCE:
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Jun 06, 2012 | Panasonic Televison & Video
Hooking up an HDMI cable to a 53 inch cinema vision rear projection tv and being able to get video and audio.
53 inch? Is this an older tube type projection set? need the model number to try to figure out what your problem is.
Mar 24, 2012 | Panasonic Televison & Video
Panasonic cinema vision tv picture is shadowed
thats a classic convergence issue. You can get the panasonic convergence repair kit for your model from www.tvrepairworld.com which has the parts and the CD with repair instructions.
Oct 29, 2011 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic cinema vision projection tv has lost it's focus. It has "double vision". How can it be fixed?
You can get the Convergence repair kit for your model at www.tvrepairworld.com the kit contains the IC, Resistors and the CD with step by step repair instructions.
Jul 18, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic cinema vision model pt47wxc43g has double image on bottom of the screen.
Sounds like Convergence Ic's are defective. The best advice would be to contact a Svc. Co.
Feb 24, 2009 | Philips Magnavox 51MP392H Rear Projection...
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Having just bought a Panasonic TX-37LZD80 television and a panasonic sc-pt460EB-K home cinema system, I connected the 2 together using a HDMI Cable and all works well except that I cannot get the sound...
When I purchased the television iI was told that I would only need a HDMI cable to connect the devices together, this is not true as the HDMI only provides 1 way transmission, to get the sound to go from the television back to the home cinema you need to use either a Phono Lead or Optical lead, plug them in and Hey Presto it works.
Jun 23, 2008 | Panasonic Televison & Video
Televison & Video Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
