Question about Coby MP-C582 MP3 Player
Won't Charge I plug it into the USB port, the red light comes on and when I disconnect it after about 5 hrs and try to turn it on with the >|| swithch there's no response. The red light doesn't come on.
There is a on/off slide switch on the side that has to be in the off position to charge, if you see a red light when plugged in it is in off, the slide must be in the on position to operate
Posted on Aug 23, 2008
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Gd yashica
The battery or charger might be bad and need replacing. Do you have a different USB port available? It's possible the port you are trying to charge from is not powered.
May 28, 2013 | JVC GR-D53 Mini DV Digital Camcorder
I barely got this camera. It wouldn't turn on so I
What make and model camera?
Not all USB ports put out enough current to charge a battery. If you're connecting through a hub, try bypassing it and connecting directly. If you have another USB port, try that.
Apr 26, 2013 | Cameras
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
It is stuck on low battery screen and charging light won't come on.
Hi imrydn!
You can try these steps:
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds at the bottom
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Aug 01, 2011 | Sony Reader Touch PRS-600
HI,I AM TRYING TO CHARGE MY BLUETREK MINI THROUGH THE LAPTOP WITH THE USB CABLE BUT SEEMS TO ME THAT THERE IS NO COMMUNICATION BETWEEN BOTH.ALSO I PRESS THE BUTTOM ON THE UNIT AND THE LIGHT BLUE AND RED...
unplug usb cable from your laptop
restart your laptop
plug USB cable in diffrent ports available
Still if its not charging then follow these steps :
1. Right click on My Computer
2. Click on properties
3. Click on HARDWARE tab
4. Click on Device Manager
5. Click on USB ROOT HUB
6. Uinstall USB ports one by one
7. Restart your laptop
Then try to charge your BlueTrek Mini
Apr 29, 2010 | Computers & Internet
When you plug the reader in to recharge is a red light supposed to come on until charged? How do you know when it is fully charged?
Yes, the red light should be turned ON after connecting the Reader to te Computer. That means the Reader is taking charge. After getting it fully charged, the red light will be turned ON. If those things will not happen to your reader, perform the below mentioned stepos::
1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Feb 02, 2010 | Sony E-reader Portable E-book MP3 Player
BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON. THE ONLY SIGN OF POWER IS THE RED INDICATOR LIGHT TOP RIGHT....ON SOLID. CARRRIED OUT REBOOT TAKING OUT SIM AND BATTERY. ANY ADVICE WOULD BE APRECIATED.
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
Player is not turning on
Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
If you are using a USB hub to charge the mp3 player then the hub must be powered.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Coby MP-C582 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
