Question about HP Computers & Internet
The monitor is black
Hello i got hp8560c the problem is when i turn on ,the monitor is black i check the cables and everything and is ok the light from the pc is on,and the other thing is a open 2 clean inside couse 2 much dust and i take the cables off,when i put the cables back ( i thing i did it ok ) the pc is no more on......THANKS 4 HELP
  • chinyta Aug 22, 2008
    thanks 4 help and i already did it and it dont work
Thank you i am going try
Posted on Aug 23, 2008
    Scholar:
  • 152 Answers
Can you use another monitor to get into the settings on your pc? If so, hook that one up. Go into Control Panel, Performance and Maintenance, Power Options. Check to see what the settings are. Do you leave your pc on all the time? That's what I do. But I turn my monitor on and off when I need to use the pc. In Power Options, make sure that Power Schemes is "always on," and choose "never" for every other option. Then hook up your monitor and see if that helps.
Posted on Aug 21, 2008
    Scholar:
  • 65 Answers
I've had this problem from even trying to restart my pc at times. it happens usually when you've changed or added something that the pc wasn't prepared to do. if you've installed a new card. disconect it and try again. installing the drivers and software for it first.
  • matthew carroll
    matthew carroll Aug 22, 2008
    my next suggestion would be to try to start your pc using a dos boot disk. it may just be your o/s. however their is the connector on the motherboard, it may have gone bad. if using another monitor didn't work, i would suggest to purchase a new video card. I use nvidia they've got some really good products.
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
I have a Dell Dimension 5100 and the monitor is showing a blank screen. The light on the monitor is flashing green. Everything else seems to be ok as I can hear it starting up.
Hello
Check the data cable (the cable from monitor to CPU), might gone loose, otherwise the monitor need be handled technically for repair.
Good Luck, feel free to contact for more assistance
Dec 18, 2010 | Computers & Internet
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor intermittently goes dark and will not come on
check you monitor cable or replce it. tahnk you..
Feb 05, 2009 | Computers & Internet
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
Computer monitor problem
ok the problem is not the monitor it is either the cable checke each end for bent pins inside or the computer you are trying to use
Jan 13, 2018 | Computers & Internet
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Not powering on
it also happened to me, but i tried to reconnect the connection to my cpu and the power cable of the monitor, and its ok. But after a while my monitor get black again. what i do is i turn my computer off and check again the power cable of my monitor, reconnect the monitor to my pc and i opened my cpu, check my memory card, i reinserted it. And it worked.
hope it also work for you
Sep 17, 2008 | ViewSonic VA550 15" Flat Panel LCD Monitor
No power to monitor
Your problem is really multiple problems. One is if the monitor blew out, the second is weather it damaged the computer when it went, the third is if the computer went first killin the monitor. I would first see if your computer is ok by turning it on with out any monitor connected and listen to hear if it sounds as usual. If not something may be wrong with your computer. If everything is ok plug in another monitor (borrow from a freind if you do not have a spare) and see that the computer is ok. If it's ok great but if there is a problem with the computer that is a whole new question.Next if the monitor's on light does not come on and you know it has power the monitor is most likely fried. Hope this helps and could use more details
Dec 29, 2006 | NEC MultiSync LCD1550ME (Black) 15" LCD...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
