Question about Tomtom ONE GPS Receiver
TomTom 910 won't charge.
I've disassembled the TomTom to Reach the battery. The Battery has three wires, red, black and yellow. Which leads should I hook up to which poles of the 9V in order to induce a small charge to the Li battery? Thank you so much for your help.
  • shnazdabling Sep 16, 2008
    Thank you so much for your answer to my question.
    To assuage your concerns of my awareness in electrical knowledge, I had made the assumption that red was positive, black was neg and yellow was a sensor. I was only concerned that making that assumption may lead to destroying the battery. I have come across some foreign technology choosing to go in a different direction with the rest of the world in color codes. It was a bit of paranoia on my part. About three days after my inquiry, I used my ohm meter to find the complete circuit and identify the positive and negative leads. Again I do thank you for your response as this was the affirmation to me that I made the right decision. Sometimes you just need someone to bounce an idea off of.
    Thank you for taking time to help me out.
    Novelist:
  • 158 Answers
Black and Red. ( red is + ) The yellow wire is a sensor wire but you just need black = neutral , red = Positive.
Please don't be offended. To be honest with you , if you didn't automaticly know this or be able to deduce this with a multimeter, then perhaps you should not be messing with it at all.
Posted on Sep 13, 2008
  • Ken Roberts
    Ken Roberts Sep 17, 2008
    Hi shnazdabling
    Can I first say that I appreciate your comments. I know exactly what you mean when you say you have come across foreign technology and yes , it sometimes leaves me baffled too. I think you did the right thing to check .
    Out of interest , most Tomtom faults that are "wont switch on" related are started with a faulty cigarette lighter charging lead. The Yellow wire in the lead is a 'backfeed' from the plug at the end . It feeds the 5v back into the cigarette lead head to the electronics. If this yellow wire ( might be white in some units ) becomes detached the circuit senses zero volts so the circuit then increases the output voltage ( in the end it goes up to your car battery voltage OUCH ! ) and this in turn ends up with 12v or more going into the TomTom.
    This in turn results in the 2 chips blowing U24 and U25 and often a 3rd chip the LTC1733 . A BIG ouch if this one goes because I have never managed to replace one without doing damage as they are well stuck to the board. The reverse polarity protection diode is also often blown too .
    As a protection against this ever happening again ( the loss of connection of the yellow wire ) I decided it prudent to make a slight modification to the cigarette lighter circuit as follows:
    • open up the cigarette lighter large plug end ( its fiddly and it tends to crack the plastic ) but it can be repaired with super glue or similar after the job is done.
    • find the solder points where the red and yellow wires are soldered to the circuit board
    • bridge the 2 joints together with either a big blob of solder or a short length of wire.
    • reassemble the connector and fix with (tiny) blobs of superglue.
    This in effect means that the circuit can never 'see' a loss of continuity and unless the charging circuit itself goes faulty , the lead can never output a high voltage.
    PLEASE NOTE , This modification would cancel any warranty and is not approved or suggested by me. I mention it here to tell what I did with mine as I was prepared to take any associated risks . if anyone reading this decides to modify or alter their product then they should understand that any risk is theirs and theirs alone.
    If I can be of any further assistance please let me know .
    Please note : In an earlier reply / post I incorrectly stated U25 type number. THE CORRECT NUMBER FOR U25 is LTC3411EMS and for U24 it's TPS6200
1996 piaggio hexagon, battery not receiving charge from engine, indicators and lights go funny with revs, is it the rectifier, the battery was brand new (gel type) fully charged about three weeks ago,...
Find the reg/rect. check the AC voltage going in, should be about 18-26v & 3000RPM. If you have voltage check the out put Red and frame should be above battery voltage.If not turn off engine and check voltage at reg/rect Red wire (+) and Black(-) if fitted could be conected through body to frame..It should be at battery voltage.if not check for burnt or dirty conectors on the red lead and or the black lead if fitted or the mounting bolt for the reg/rect.
If you have battery voltage and AC voltage at the reg/rect suspect the reg/rect. some units have an extra wire that can be an ignition feed that has power on it when the key is on, but sure these dont have it.
If you dont have AC voltage check the (usualy) yellow wire some can have 1 or 2 wires. If it has 2 wire check voltage across both, if it only has one check yellow and the frame.
Sep 16, 2010 | 2005 Gilera Runner VX 125
When removing the 910 from power lead it dies, which leads me to think batteries are dead, can the be pelaced by owner or be returned to TomTom?
well the battery is intended to be replaced by TomTom professionals, but you can change it yourself if you have the proper expertise, You can buy the spare battery from Ebay etc.
Jul 16, 2010 | Tomtom GO 910 GPS Receiver
Battery won't hold charge on tomtom 910 - the green light comes on when i plug it in but as soon as i unplug it the warning battery light comes on
Your battery has finally died and needs to be replaced. To replace the battery in your 910 you must completly disassemble the 910. While battery replacement is fairly straight forward, it is not a job for the average user.
Oct 20, 2009 | Tomtom XL 330 Car GPS Receiver
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
ALL Voltages (three wires) iones battery of Ton Tom one
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
Jul 23, 2009 | Tomtom One XL GPS Receiver
Why there are three wires in battery of Ton Tom one
You can get a multi meter from an electronic story really cheap.
It will tell you the voltage and the polarity of the battery connectors.
Jul 22, 2009 | Tomtom One XL GPS Receiver
Battery replacement for TomTom 710
I have found a trick for those bad battery ,but you lose your waranty
you need to open your tomtom , behind the screen you wil find the battery(for the Go 710 it is an 3.7 V ,2400mAh,samsung ICR18650-24)
you find 3 wires : red, black,yellow cut them of at the half of the wire size
, then cut off your car loader wire (tomtom)(5v), you will see again 3 wires inside :red,black,white
connect the red with red, black with black, white with yellow
(the best thing is to make a little hole in the cover to pass the wire, so it will be beter for closing the all thing)
I did it and it works pretty fine ,I had save 30 dollars ;) :D
I did in approximatly 30 min
remember you will have no battery any more and no waranty of tomtom!
It only whorks then with your car loader tomtom
Jan 20, 2008 | Tomtom GO 510 GPS Receiver
TomTom 910 system
The unit has a lithium-ion battery and can be subject to being "overcharged". Try COMPLETELY discharging the battery and then recharging for 4 hours.
Jun 29, 2007 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
685 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
