Problem with digital port for tv samsung 32" - Televison & Video
I got samsung la32b450c4. can u explain how can i use that usb port which reads service. or can i connect that service port to pc usb or is there any option to upgrade the software or something
Hello
First of all, it is not a USB port/slot, it is a 3.5 mm slot. And it can only be used Samsung technicians for "service" and nothing else.
Thanks for using Fixya!
Aug 25, 2011 | Samsung LE32A457 32 in. LCD TV
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
I'm trying to view my monitor on my LG 32" using the RGB port but can't get it working? I've connected the monitor cable to RGB port, selected the RGB menu in Imput and keep getting "NO...
I too am having the same problem. It works fine on my Samsung TV but no signal on my32lG60. If you find anything let me know. Larry mebehe.Larry@gmail.com
Dec 01, 2010 | LG 32LG30 32 in. LCD HDTV
Gentlemen; We purchased a 32 inch hygh def TV app 3 years ago. We had an issue with a burned out 32 inch model and had a certified repair tech come up to our home and had the main board replaced in I...
Please note that we are not affiliated with any company. We are a bunch of independent consultants with hands on experience at fixing stuff. However if you can get me the make and model of the tv along with country of residence I can get you the contact info of the customer service department so that you can get it replaced.
Oct 31, 2010 | Televison & Video
PROGRAM COMCAST DVR REMOTE TO WORK WITH TV
Digital Lifestyles 42in 1080p FA2B-42570
For DISH Network users: I found that the Citizen brand remote code #523 worked for the sound, mute and power. This is for the remote that comes with the standard DVR, im not sure about any others.
** This was added to the 32in product page because there is no listing for the 42 inch yet.
Oct 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
Feb 26, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
