Hitachi 46w 500 screen says locked - Televison & Video
  • 6 more comments
  • linderlcc Aug 22, 2008
    there is no reset button just menu and input
    I do not have a users manual
    this does not help, if any one has this tv and this problem please respond
    no it does not
    can i get the number for hitachi again please?
    called hitachi they told me to call a tech
    this has happened before about a year ago and i found the solution on line, but i can not find it now.
    I have called Hitachi and they said that they do not have a solution to the problem
  • Televison & ... Master
  • 19,396 Answers
Try doing the following, you will need to use original remote:
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Keep me updated, and if this work do not forget to vote the solution.
Posted on Aug 23, 2008
    Sergeant:
    Champion:
  • 298 Answers
The lock function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select secret code.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (❒ TIME LOCK) you can set the BEGIN and END times (THUMB STICK ) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR  or  to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY (TV will time out one time a week).
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
If ANT A and ANT B are in the same signal source mode, when a channel is locked, it is locked
on both antenna inputs.
Posted on Aug 22, 2008
  • 4,472 Answers
I believe the first thing to try is holding down the zero button. Let me know if that works. If not I will assist you further. Please don't reject my solution til I solve your problem. If this helped please accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 22, 2008
    Also have you tried unplugging the set for a couple hours yet at all? That is always one of the first things to try as well to reset your tv.
    Thanks,
    Lee
  • 2,071 Answers
After all this time i finally unlocked my Hetachi and i have the answe so for all who needs a solution im posting it , HOLD UR MUTE BUTTON, AND WITHOUT COMING OFF IT GO AND PUSH EACH BUTTON ONE AT A TIME, ONE OF THEM WILL OPEN IT, ALL TVS DONT WORK ON SAME BUTTON, LET ME KNOW UR RESULTS MY PEOPLE.......................MINE BEEN LOCKED OVER TWO YEARS
Hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Sep 01, 2008
    Did the solutions from all of us experts solved your problem if
    not then let us know the current updates so all the fixya experts can
    assist you further.
  • 2,337 Answers
Click here to download the use's guide and go to page # 72 to find the factory password.
  • Jaime Hernandez Aug 22, 2008
    Try the factory password from the link I've sent you.
    Can you see my post answering your questions and giving you a solution?
    Master:
  • 638 Answers
Open the unit from the back by removing the screws there you will find the power supply board.on that power supply board from inside you will find the very small black colour button just press the button and the tv will get reset and ready to use.it is very simple,but if it is not possible for you call the technician and get it done.the cost will not be more then his service charge.thanks.any thing else let me know.
    Master:
  • 848 Answers
Does your tv asks for any kind of pin code when the screen is locked ......
    Master:
  • 623 Answers
Go here
forum.ecoustics.com/bbs/messages/2/246952.html
  • Anonymous Aug 22, 2008
    try this site
    www.hitachi.com/
  • 6,487 Answers
Try checking the user manual if you had it handy with you hopefully there's a solution for that problem from the user manual...
Good luck..........
  • 2 more comments
  • Mark Gil
    Mark Gil Aug 22, 2008
    Better call Hitachi for this concern the number is 800-4482244..
    Good luck..........
  • Mark Gil
    The number is 800-4482244
    Good luck.......
  • Mark Gil
    I think its time now to call Hitachi and let them fix this problem for you...
  • Mark Gil
    Is this still under warranty?? because if even them dont have solution they should replace this for you..........
    Master:
  • 521 Answers
Reset the tv by pressing the reset button.
Posted on Aug 21, 2008
SOURCE:
I have an old Hitachi wall mounted TV with a diagonal locking bar. How do you release the locking bar?
If you wish to get more details, visit the site linked below. Screen faults of both Plasma and LCD screen are given with details and illustrations. http://electronicshelponline.blogspot..com/
Jan 07, 2017 | Hitachi Televison & Video
Hitachi 46F500 SCREEN SAYS "LOCKED"
try 1234 or 0000 or call http://www.shopjimmy.com/ and talk to one of the techs on site
Sep 04, 2012 | Hitachi 46F500 46" Rear Projection...
Blue screen and the colors have been off for a while. We replace tbe light bulb last year. What else can it be?
this is a bad light engine, a costly part of the set, the heart of the tv. sometimes you can clean it out, but usually on the hitachi's it needs a whole new one, estimates run from 500-1000, sorry to be the bearer of bad news.
Sep 09, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi sp-46w - picture is fuzzy, ran magic focus and stops 1/2 way in the green. A code appears at the bottom right "5" any clue?
Ur convergence,it dead,need it replaced,Know how to solder?Buy a convergence kit,tries Tv repair World.com,Tv repair kits.
Nov 24, 2009 | Hitachi 46F500 46" Rear Projection...
My Hitachi 51S500 is showing a black screen
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
Hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Oct 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Help
Please check HERE for front screen of your Hitachi projection tv.
Oct 18, 2008 | Hitachi Televison & Video
65 S 500 HITACHI
I would suggest contacting the local Tv repair shops in your area to see if one is available used, as many shops save the screen assembly when they disassemble a set that isnt worth repairing. It may be available through Hitachi, but doubtful. I have sources for screen assemblies but unfortunately not the 65 in screens.
Mar 26, 2008 | Toshiba TZ50V51 50" Rear Projection...
LOCKED HITACHI TV
need model and chassis number and I' may help you email me
Mar 20, 2008 | Hitachi C21RF39 21" TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Ekse
