To set the clock: 1. Press the clock key 3 items until the hr/min icon flash. 2. Press the + or - key until it come to your desired time. 3. Press the confirmation (check) key.
You have your time. If not, call the service support.
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
To set the clock: 1. Press the clock key 3 times until the hr/min icon flash. 2. Press the + or - key until you come to your desired time. 3. Press the confirmation (key or tick) key.
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
gaggenau
