Question about Intertherm Heating & Cooling
Wiring diagram for intertherm furnace E2EB-015HB
koolbreezes
  • 540 Answers
SOURCE: I NEED WIRING DIAGRAM FOR
Web page or the unit door covers , Intertherm are mostly added to trailer homes and check out a trailer home supply house.
Posted on Sep 03, 2008
  • 96 Answers
SOURCE: heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Posted on Dec 10, 2008
  • 116 Answers
SOURCE: My central heating and air-conditioning unit completely stopped working - the model# is e2eb-015hb
manually bump the contactor whare the main power comes in with a insulated object isf unit starts then check for call from stat on stat wire from common to red 24v ac transformer good or see if indoor fan comes on next check call from stat common to yellow 24 v then look for low psi switch to see if it has it locked out could be low on gas
Posted on May 09, 2009
flatech
  • 111 Answers
SOURCE: I need a wiring diagram for a intertherm model #
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Posted on Nov 03, 2009
  • 99 Answers
SOURCE: Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Posted on Feb 20, 2010
Intertherm electric furnace model E2EB-015HA. Upper element will come on and run continously in 20 degree temp, Lower two elements don't come on. What's up?
Sounds like one or 2 stages of the sequencer is not kicking the other elements on. -OR- the limits ie klaxon switches in series with your elements are stuck open.
Dec 08, 2013 | Heating & Cooling
I need a wiring diagram and sequencer part Number for e2eb-015hb nordyne electric furnace
any sequencer will work as long as you have the same number of stages. hope this helps.
Aug 09, 2011 | Heating & Cooling
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
May 08, 2009 | Intertherm P3RA-048K Air Conditioner
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Heat comes on fan does'nt
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
2,490 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
