Washing Machine HOTPOINT AQXGF149PM
Length of cycle does not match the minutes displayed
  • amanda65 Aug 22, 2008
    Yeah that could be the problem, it is true that i did put extra detergent in as there were some stains. It was also quite a large load, I also chose the extra rinse option. When it got to the end it said it only had 0:01 minute left to go but it went on for ages. (the cycle said it would be 2:30 - but it went on for about 6:00 hours!)
    Genius:
  • 1,028 Answers
Remember ..time displayed is only estimate fill time slow pump out oversudsing and off balance loads may cause longer times than displayed..ck owners manual
Posted on Aug 22, 2008
How do I stop my Hotpoint washing machine WMF740 which has been going for 7hours and is stuck on 1 minute
Is there a way to manually advance the cycle or is it all digital control panel? Do you see a reset button anywhere? Check the link I'm sending you on the manual.
Hotpoint Washing Machine Instructions For Use ManualsOnline com
Nov 24, 2014 | Hotpoint Washing Machines
The light that displays the length of time for the cycle is flashing and saying F01 and the machine is not commencing
Try unplugging the machine for at least a few minutes - if this doesn't work it will be a engineer call out.
May 03, 2011 | Whirlpool Duet WFW9550 Washer
Hotpoint WMF940 Washing machine - 11 months old. The cycle times displayed do not represent the actual times. No 5 cycle takes over 3 hours. The other displayed cycle times are similarly not...
If it is indeed less than a year old, then I recommomend you contact Hotpoint direct as the washer will still be under the years guarantee,and you should get a call free of charge
Check with Hotpoint at the web address below.
They should be able to help you.
WWW.HOTPOINTSERVICE.CO.UK
Jan 03, 2011 | Washing Machines
Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Blue display gets hot and has faded
hi, it may have a dry solder joint you could find.
a new display can be bought from hotpoint for about £55 according to their website.
http://www.hotpointservice.co.uk/hs/pages/index.do
if your machine is less than a year old it's a guarantee job, if under 5 they fit the part free but charge for call out. a local engineer may give a better quote. it's a 5 minute job to replace.
Feb 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 Washer / Dryer
Firstly unplug the machine. Take it outside, use petrol + match. Go Currys and buy anything other than a Hotpoint.
All serious apart from the petrol and match, as that could be dangerous.
Jul 30, 2008 | Washing Machines
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
