Question about Compaq Evo D310M 845G P4 Motherboard
NIC Driver Hello, I have an Asus ABMZN-LA motherboard in my computer,running XP Pro . When I try to set up an Internet connection all I get is a 1394. What I want is to have the NIC on the board to work but I don't have the Drivers CD for this Board. Can you help me? My email addy: dudleybirch@hotmail.com Thanks Alot
  • Compaq Master
  • 3,051 Answers
If you go to www.driverspro.com they can help you there ok hope this is helpfull best regards mike
Posted on Aug 22, 2008
  • Michael Thomas
    Michael Thomas Aug 22, 2008
    put a dot between drivers and pro sorry about that iam at the site right now
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
I need a Ethernet controller driver for Asus p4s800d-x Windows 7
If you are trying to connect through a modem/router you it should have come with a disk then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver will be on the disc supplied by your ISP internet service provider
hope this helps
91313.html
2112_4-91313.htm
hope this helps
Mar 31, 2011 | ASUS P4S800D-X Motherboard
I can install the driver i downloaded from the internet but i still can't hear an audio output. i only hear an static sound.
Try downloading the audio driver from the ASUS WEB site.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 20, 2011 | ASUS P4B533-E (P4B533-E/L/1394)...
My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Feb 04, 2010 | Computers & Internet
Problema scheda audio
in che lingua avete la tua xp?
secondo ci ai provato in asus site per la tua driver o no?
chiariscimi a la tua condicione ancora una volta, provi un altra volta andare a asus site , dopo se non ci riesci scrivimi , e lo aiutero trovare la tua driver.
Apr 10, 2009 | ASUS P5VD2-MX SE Motherboard
No internet sites reachable, nothing appears to be wrong
Have you set it up for network through windows network setup
also check network name the same (I had one that i thought was correct and one letter in network name was different and would not connect)
Nov 19, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
ASUS P5N32-E SLI AND INTERNET INSTALLATION
It sounds like a missing or incorrect LAN/NIC driver.
Pick your OS under the LAN menu on this Asus site
and download the current driver for the NIC.
Feb 17, 2008 | ASUS P5N32-E SLI PLUS (0610839148967)...
DRIVERS
check the chipset (VIA, SIS, INTEL or others) install the cd motherboard driver. Or connect your pc online then restart your computer.
Feb 03, 2008 | Compaq Evo D310M 845G P4 Motherboard
Modem conection
In order to troubleshoot this problem, I need the following information:
Are you using a router?
What OS do you have?
Does your modem have a steady "online" light?
What IP address is coming up in ipconfig?
Oct 03, 2007 | Computers & Internet
Compaq Evo D310M 845G P4 Motherboard Logo
187 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
