32" CU32FS51 5 year old Sharp TV just powered off while viewing won't power back on. Is there a fuse that could be replaced in the chassis somewhere?
What a rip-off. NO I didn't solve my problem -thought this stupid service was supposed to get my verification before it charged me - I got a computer guy who didn't know squat about televisions and then an UNauthorized charge to my PayPal which I am trying to cancel. Unless that is reversed I will never use this service again and be sure to tell the world!
Posted on Aug 22, 2008
TV all the sudden won't power on. Where is the fuse located?
Follow the power cord inside the set as it goes almost directly and non stop to the AC line fuse.
Dec 06, 2012 | Sharp 32U-S60 32" TV
I have a sharp lcd 32 inch it stopped working, it won't turn on.
Try to check the main line and if its ok proceed to the power chord then to transformer or the fuse and you look it they are fine look for a technician to check your tv.Choose a better technician near from your place.
Nov 06, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
Our 32" flat screen 2
Please replace power supply board in tv to solve its problem.
Required power supply board is available in shopjimmy.com under $100 and local tech will replace it.
Thanks.
Apr 21, 2011 | Sharp Televison & Video
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television I have a 32" tv Westinghouse, it was on went I hear a sharp pop like glass breaking, I unplug it for a willy plug it back in and nothing happen what...
Ur power supply board is dead.Take ur tv aparts,replaced the power supply board.Ur tv will get ur power back an the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sharp 32" aquos LCD tv, will not power up with remote or switch on set, has power (120v) to end of cord where plugs into back of tv
This is usually some sort of power supply shut down problem the TV has detected a major fault, and has shut down the power supply to avoid a fire or explosion.. you need to get this unit serviced by a reputable repairer also always ask for a 'Quote: so you know weather to repair or replace.
Mar 21, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Wont turn on. is there a fuse or something inside
The unit has fuses but you will probably not find any bad ones. I would check the power supply for problems. If you unhook all but the control board it should produce all it's voltages which are usually marked by the connectors. If voltages are good the problem is in one of the boards which are unhooked. It would need replaced. If the voltages are not there the power supply board needs replaced. Let me know how you make out.
hardrocko
Jan 31, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
The power button on my sharp LC32sb24u tv is blinking green and the tv wont turn off or on.
is the OPC light blinking also if it is the tv neds to be reset by a certified shop. OPC is an engineering flaw from Sharp and conflicts with other software in the tv.
Jul 10, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp aquos lc-32
Exactly the same problem with mine, Sharp quoted £160 fixed price !!!! -
fixed in the same manner as detailed, many thanks.
Pics attached ... Before
Then screws removed ...
355f6f8.jpg used light emery papaer to clean the contact points between the pcb and the Chassis.
Back togetther all working fine.
Oct 18, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No power
You could have a bad high voltage transformer or problem with the power supply. If the set is over 6 years old, It would probably be better to replace it.
Jan 13, 2007 | Sharp 32F540 32" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
