Question about JVC Cybercam GR-D70 Mini DV Digital Camcorder
I'm trying to get video from my JVC GR-D70 mini DV recorder to my PC. I run on Windows 2007. I have downloaded the Windows Live Movie Maker and Photo Gallery. Using a USB from my camera to PC I am able to get photos off the memory card but cannot access the video tape. Help!?
  • JVC Master
  • 17,130 Answers
You are not able to convert the DV to digital data because there is conflict of the format and the type of file. So it is required that a software must be downloaded to the PC so that the DV files are copied and converted.
Please check the following link and download the program to be used to convert the DV files.
Click on:
http://www.xilisoft.com/dv-to-dvd-converter.html
You can convert the DV to DVD by using the converter.
Posted on Jun 22, 2011
SOURCE:
INEED TO DOWNLOAD SOFTWARE TO CONNECT CAMCORDER TO MY PC TO CONVERT VEDIO TAPE RECORDED
To transfer video from this camcorder to a PC, you need a 1394 cable (also called a "Firewire" cable, and your PC must have a 1394/Firewire connector as well. You can use Movie Maker (which comes with Windows) as the capture software, or you can download Scenalyzer (shareware), Studio (from Pinnacle), or Vegas Movie Studio to do the capture.
Jan 25, 2011 | JVC GR-D870 Mini DV Camcorder
I HAVE JVC GR-D347U MINI DV BUT I HAVE NO SOFTWARE TO MAKE A MOVEIES SO WHEAR I GET SOFT WARE
your windows pc should have a movie maker program, go to start and then to programs, look around there form windows movie maker.
Apr 25, 2010 | JVC GR-D347U Camcorder
Im trying to transfer viedeo from a JVC GR-DVM96 vis usb to mini usb. Do I need to use the dv port?
Hi, connect the cam and PC using 4 pin firewire cable (not USB cable).
Switch on the cam.
Open Windows Movie Maker and import the video from device.
Dec 29, 2008 | JVC Cybercam GR-DVM96 Mini DV Digital...
JVC 34X GR-D770U
Hi, You should connect using 4 pin Firewire cable to download the video. Also use Windows Movie Maker software.
Oct 27, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Oct 07, 2008 | JVC GR D370US camcorder Mini DV
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
cheers,
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Jvc gr-d395u video camcorder, move mini dv to computer
How it's supposed to work is to get a program that recognizes the camera, then the tape can be captures. Windows Movie Maker never supported it. In fact Microsoft doesn't even support it anymore. They have recommended using Pinncale Studio to work with DV cameras.
Once you install Studio, put the tape in, turn the camera on, Studio will load up.
Aug 09, 2008 | JVC GR-D395 Mini DV Digital Camcorder
JVC gr-d70 connection / uploading
wrong connection! you must use firewire to stream video and audio from your cam-make sure comp has connection-called 1394-on cam it's called dv and get proper cable and you will be fine-usb only for pics
May 23, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
Feb 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Problems recording onto memory card with JVC GR-D70
DUDE u can only take some stills in the memory mode. no vedio recording is available in memory mode. Thats not a problem DUDE. i got the same model.
mail me mohammedshafit@rediffmail.com
Dec 28, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
JVC Cybercam GR-D70 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
