Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Compressor not running
Is there something I can check, the lights inside are on but the compressor is not coming on...it has been unplug for about 6 months
Thanks, I will try it tonight!!!
Posted on Aug 22, 2008
  • 958 Answers
Have you plug it more than an hour?..if the timer is in the heating mode, it would take about 30 mins to finish and transfer to cooling mode, try to wait...
is the thermostat set to the max?...set it to max so that the compessor might run...
let me know what happen ...
tnx for asking me...
drcool
Samsung RF265AARS 6 years old been sitting unplugged 5 years wont start
Remote chance fridge is on defrost cycle but more likely the compressor has seized.
Have it check by a qualified tech.
It's usually cheaper to buy another fridge than to have the compressor replaced and new refrigerant installed.
Nov 02, 2017 | Samsung Refrigerators
Deplay light and inside light off,door ajar and compressor running
I appreciate your inquiry, stephen couch!
From the information you have provided the lights on and inside of your freezer are off and your compressor is running. This sounds like a possible short within your control panel or wiring issue. I see you have performed a reset on your freezer by unplugging it and plugging it back in. Typically, to perform a factory reset we would suggest unplugging your freezer for roughly ten minutes. If that does not help I would suggest having a professional come out and perform an accurate diagnosis. This will help avoid any unnecessary part purchases. Best of luck! -Matt
Jan 31, 2015 | Frigidaire Freezers
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Frezzer runs but the compresser does not comes on
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this helps.
Mar 04, 2011 | Frigidaire Freezers
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
4. Wait one hour.
please rate my answer.
Feb 21, 2011 | Amana Refrigerators
Not getting cold
you need to replace the ptc overload relay located on the compressors body,it isnt actually running right,and the compressor will be quite hot,do this soon otherwise the compressor windings will overheat and destroy the compressor
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
I have side by side refrigerator model 106-52709-100. Light is on, I can hear fan running but no cool air in side. Actually, thers is no air coming in inside. What is the problem and how to resolve ?
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 21, 2009 | Refrigerators
Moved refrig from one locatation to another power will not come on , pluged it in no power it will not start
If you laid the refrigerator down you will need to wait until the compressor oil settles back to the compressor. Check your outlet with a light and your circuit breaker. If it tried to start before standing overnight the compressor has to pump the oil first before the freon. This will trip the breaker sometimes. But if the lights are on inside and fans running unplug and wait a few hour. Hope that helps. Let me know if you notice something different. Thanks, Sea Breeze
Aug 15, 2009 | Refrigerators
How can I tell if my fridge isn't working?
Unplug the Ref for 15-20 min. take off the cover so you can see the compressor, then plug it back in and listen for the compressor to start. You should be behind the Ref so you can tell the difference between the fan running or the compressor.
The compressor should start and keep running.
The fan cooling the compressor should be running.
The fan in the freezer should be running.
You should feel cold air coming into the Fridge side from the freezer side.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
66 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
