Question about Weber Q Grill
Weber Silver B - 3 burner BBQ
Im getting very low heat. All three burners are burning but very low. I check the valve connection at the tank - everything seems O.K. Any idea what it might be? Skubadiver Grill won't heat over 250 degrees.
  • 3 Answers
Check your instruction manual, you have probably set off the safety valve in your propane tank. It is set to trigger if there is an open connection, such as turning on the jets when the tank is turned off. You may have to re-connect the tank...careful of course, make sure it's valve is off.
Posted on Aug 24, 2008
When the grill is on high heat for all 3 burners only heats up to
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Apr 05, 2010 | Weber Genesis Silver B Grill
Weber grill three burner. New tank of propane but
Mar 29, 2010 | Weber Genesis Silver B Grill
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
May 07, 2009 | Weber Genesis Silver B Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
Weber Silver B grill
I bet your grill gets no hotter than about 300 with the lid closed?
The tank has a built in safety feature. If a burner is left on when you open the valve on the tank, or turned on too soon immediately after opening the valve on the tank, the flow will be restricted. You need to turn all burners off, close the tank valve, disconnect the tank, reconnect the tank, open the tank valve, waqit a few seconds, open the burner valve and light. You'll get unrestricted flow and much better heat.
Oct 31, 2008 | Weber Genesis Silver B Grill
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Weber Q Grill Logo
452 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
