Question about Whirlpool Washing Machines
Hi my problem is , I want to buy a washer front load
Length of cycle does not relate to time displayed
Posted on Aug 21, 2008
SOURCE:
AWOE9140 (859201315010) bearing
It is cheaper to buy new top load washer than replace bearing on old front load washers these days
Dec 09, 2013 | Washing Machines
My washer knob broke when I pulled it out to start
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 21, 2011 | Frigidaire GLTF2940ES Front Load Washer
Roper washer won't do final spin.Can I easily fix it or should I buy a new washer?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 19, 2011 | Washing Machines
My washer when it is on the spin cycle wobbles back and forth almost like it is off track somewhere buts its not off balance. It hits each side of the washer like its lose, and instead of spinning around...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Jan 30, 2011 | Maytag Neptune MAH6700A Front Load Washer
Hi my amw5125 front load machine makes an awful whining noise when it slows down or speeds up,could u please advise on the problem and action that is required? many thanks
when in the spin it bangs and is noisy you have a bad spider gear.this is usually from using to much detergent,it eats at the metal spider gear until it breaks,unfortunitly it's cheaper to buy a new washer than to repair this problem.next washer you buy read the instructions on how much detergent you should use.the whirlpool duet is the best front load out there right now but whatever washer you buy you should be using 1/4 cup of h.e. detergent.there's alot less water in front loads and the spider gear is made of soft metal and extra detergent eats at it until it breaks.you can also check the shocks but i've found most of the time if the shock is broken it's from also breaking the spider and the extra movement breaks the shock.you can try calling whirlpool and see if they can do anything for you.good luck
Jan 23, 2011 | Whirlpool AWM5125/1 Front Load Washer
MY WASHER WILL NOT SPIN IS. THERE A PART ICAN BUY TO FIX THIS MYSELF?
heatman101
Nov 01, 2010 | Kenmore 44102 Front Load Washer
This was will go through the whole wash cycle until it come to spin the clothes out then it will just stop it will not ring the close out. What can be the problem?? Please help me so that I don't have to...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 30, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
How do i find out what size base to buy for my front load washer? so its higher up.
if you are buying one from a place like lowes or home depot.the are standard pedistals all you have to do is tell them what kind of washer you have'
Feb 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Buying a front load washer
NO, All of the fridgidare products are bad. Buyer beware. Check out more internet if you need further warning. Spyder bracket and drum bearings on the front load fridgidares are a money pit. Buy and LG from anyplace but Sears. Buy anything otherthan GE,Electrolux, Kenmore, Hotpoint from Sears.
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
15 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
