Question about Packard Bell (ATXMH28AP) Full Tower Case
Computer not loading up strange symbol indicating some problem
When I last turned on my computer as normal the tower lights up and the fans switch on. However the computer isnt loading and a symbol has light up on the tower in shape of can or cylinder that flashes on and off theres also a noise as if somethingh is getting stuck. Id like to know what the symbol means, I havent done anything drastic to my computer since I set it up so any ideas what could have gone wrong would be apresheated
  • sparrish11 Sep 08, 2008
    when i power on the computer, it goes through the motions to try and read the disk drive. it hums and the screen doesn't show anything. the computer is getting power. at our last place, it was running fine. since we moved, i can't boot up the computer. i checked all plugs and wires. everything is connected properly. how can i get it up and running?
  • 2,028 Answers
That is the hard drive symbol. The noise is most likely the hard drive, and I would say that your hard drive has failed/crashed and needs to be replaced.
Posted on Aug 21, 2008
There is a curser on my monitor at start up. How can I start my computer again normally and get to windows.
the cursor is a command prompt waiting for an instruction from the OS
it indicates that the OS is not progressing in the hard drive
take it in to a computer repair shop and have them diagnose the problem
Oct 02, 2016 | Computers & Internet
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
Our fan is constantly running now for the last last 3 days when our computer is on. We have the computer on all day and shut it down at night. It is louder than normal. Why is this and can it be fixed. ...
Its not a problem if you have the computer running all day long. Get an additional fan for your computer. An additional fan will reduce the noise as more fans running at low speed produce low sound that a single fan at high speeds. Make sure that the CPU is free from dust. More the DUST, higher the heat and higher the noise.
Dec 28, 2010 | HP Hewlett Packard Pavilion Slimline...
The computer has on occasion crashed for no apprent reason. I had the power supply out and it has normal light indications until it i plugged into the mother board. I have had itwork normally, for a...
Bad Power Supply. Weak voltage power rail.
Bestec is a low quality power supply. Used to save the computer manufacturer money.
Also, a Power Supply with a weak voltage power rail will put out enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on, and/or keep it on.
A) ALL the LED lights use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
Replace the Power Supply. Clean the inside of the computer out, with a can of compressed air for computers before installing.
What is the computer manufacturer name, and Model Number. The Model Number is on the back of a desktop computer tower next to the Windows product key, or up on the side of the computer tower.
Post back in a Comment.
Dec 04, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Aloha Breeze 32" fan worked last night, but will not turn on today. Nothing looks burned out - cord in new condition. This fan is in like new condition with no damage and is verry clean.
Mine does the same thing. when I turn on the fan I get 2 beeps. I don't know if this was normal or indicates a problem. If you get it fixed please post solution, I will do likewise.
May 31, 2010 | Tower Aloha Breeze Fan
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
. Led will light up but cpu does not power up.
Does the CPU fan rotate? And no monitor activity? Sometimes the hard disc has some kind of activity. This could be attributed to loose/failed in memory in the syste. You can try to reseat or clean the memory edge connector with clean eraser. But power down first yur unit and unplugged to wall socket no power connection shall be connected.
Sometimes it doesn't make any beep code. If beep is generated this could be video problem. But check first the Ram and video, before getting to anything.
Post an update.
Jun 03, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
Compaq Presario fan problems
the fans on a computer tower run all the time to help keep the pc cool. this is normal in a tower pc of any brand
Dec 04, 2008 | Compaq Presario Fan
Computers & Internet Logo
186 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
