Zyxel 661H Wired Router. I am successfully able to ping router from my PC, but am unable to get a connection to 'the net'. All LED's are on, showing the routers has connected to ISP. Have tried a second router and all is working ok, i.e PC to ISP connection.
Hi lafalot,
Many thanks for the reply, yes I have 'reset' the router and completed the 'setup wizard' settings, but still cannot get a connection to my ISP. I guess the router has 'thrown in the towel', hopefully it can be repaired :-)
Regards
pazthegorm
Posted on Aug 22, 2008
Hi lafalot,
Regards
pazthegorm
    Scholar:
  • 152 Answers
Have you gone into the settings page to set up the router? If the second router works, then it's possible the first one is defective.
I have forogotten my password for my zyxel router. how can i get it or change it so that i can connect to the internet
the quickest solution would be reset the router once . Resetting the device would bring it back to factory defaults .
Hope this helps
Thanks
Ranjit ranjit@supportminds.com
Aug 11, 2009 | Zyxel Prestige 661H ADSL2+ Modem + 4 port...
P-661H-D3 zyxel problem?
The fact that it does not get an IP address almost certainly means that the router is KAPUT. You may try to add in a manuel address. In you network settings of your computer you can put the following IP addresses:
IP Address : 192.168.0.100
SUBNET MASK : 255.255.255.0
GATEWAY : 192.168.0.1
then try to see if you can connect to the internet (see if the internet light then comes on.)
Let me know if it works. I may still be able to help you after that.....
My email = doc@plettcomputerdoctor.co.za
Jul 15, 2009 | Zyxel Prestige 660R Router (P660R)
I am unable to get into my Prestige 334 configuration screen
Read this its the manual for your router.
http://www.zyxel.com/DownloadLibary_ShortName/P-334/quick_start_guide/P-334_1.pdf
May 29, 2009 | Zyxel Prestige 334 Router
I want to run a laptop via a zoom router off the same modem I use for my computer which is cable.I cannot get the laptop to recognise the router
pl set the ips , thn connect the ethernet, see if the net icon says ethernet connected,ping the ips including self ping,if unsuccessful chech ips , if successful, ping modem , if unsuccessful check router, ifsuccessful , connect to internet.
Nov 28, 2008 | Computers & Internet
Configuration Utility
Can you ping the router? I mean open a dos shell, type ping -tf 192.168.1.254 - what are the results? Maybe the ping fails, because you need to have your pc set to the same subnet address, to access the router on that IP. Test ping to your own gateway address first.. That will work & show you what to expect from a working ping. You get the gateway address by opening a dos shell & typing ipconfig /all - that shows the current IP address plus the gateway address. Actually, the gatway address might be the same as the router config address, unless you have a NAT function turned on.. Anyway, if you change your IP address to 192.168.1.252 - For example, you will no longer be able to access the internet, but shud be able to enter the configuration web page of the router.. Try the router default settings first. Another thing is that some routers require a direct cable called a 'crossover' cable to connect to the router or you have to go via a hub or a switch, with standard ethernet cables.. This probably looks confusing, but if it does not help, pls post your questions here.. Rgds,
Jun 24, 2008 | MSI RG54G2 Router (MS-6848-002)
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
Simultaneous PS3 and 'net connection probs.
Further to previous you understand correctly. The computer is using a wired connection, the PS3 connects wirelessly. Computer is windows XP. Don't know what firmware is, sorry.
Jan 12, 2008 | Zyxel P660HW-D1 Router
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Unable to configure
chek weather u have a static ip address in the pc>and changed the ethernet cord and changed ether net port on the router to connect the pc>and reboot every thing
Oct 08, 2007 | Zyxel Prestige P-330W Wireless Router...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
