Question about Roper RAS8445KQ Top Load Washer
Roper washer agitater won`t turn
My agitator will not turn
Posted on Sep 04, 2008
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Roper washer
That could be your lid switch. You should hear an audible click when you shut the lid. If the washer act like it is trying but won't spin that could be the drive coupler. I have a page which includes a service manual HERE
Sep 24, 2012 | Roper RAX4232KQ Top Load Washer
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Aug 06, 2008 | Roper RAX7244KQ Top Load Washer
Roper by whirlpool model # RAX4233PQ0
i assume that's a top load and not a front load as pictured..ck wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Jun 20, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Roper Washer
The gears in top are stripped out need replacing, take cap off agitator and take out bolt pull agitator out ..pull top part agitator off and replace gears
Here is what the gears look like for the top part of the agitator
top part of agitator
bottom
Oct 17, 2007 | Tecnik TKL9260 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
105 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
