Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Harmony washer I received a error message and did the diagnostic test. It told me that the motor was not working properly. I replaced the washer and it worked fine. I was able to wash two loads of clothing. When I went back I noticed that the screen was black. I tried pressing buttons but nothing happen. I changed the switch in the circuit breaker, i checked the wall unit. My machine would not come on. Please help. What could have possible gone wrong?
  • tobmsmary986 Aug 22, 2008
    the machine is less that 2 years old
Yes i did and that's why i got a new motor.
Posted on Oct 05, 2008
  • 725 Answers
Did you get a "motor is not rotating properiy" error?
if you did there are 5 thing that can cause this error... let me know what error you did get? I can help...let me know
Posted on Sep 13, 2008
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: harmony washer
It could be several things post your email and I will send you the sservice manual this way you can trace it out
Posted on Aug 21, 2008
GE Profile Harmony Washer WPGT9350COWW - Motor is not rotating properly
I once found the lid switch on a model similar to yours that was in between working and literally falling apart. When we removed the front and popped the top the **** thang fell apart. We bypassed it completely and it magically came back to life. Far as I know it still kickin.
Jun 13, 2012 | Washing Machines
I am getting the F1 error message everytime I use my washer with all cycles. I keep hitting pause then restart until it finally completes but sometimes it may restart 5 or more times to complete rinse/spin...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting an F1 error on the washer
Jul 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting error message F1 51 what is this
May 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
F1 error message
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@$#
Nov 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Whirlpool Cabrio Washer Error message code F1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$@%^
May 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%$#
Oct 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Harmony washer
Aug 21, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
183 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
