Washing machine dumps water on floor sporadically. All suggestions as far as maintenance have been followed.(Filter, proper HEI detergent,cleaning of door, etc.) Also, the problem seems to be worse when liquid bleach is used.
    Genius:
  • 1,028 Answers
Removed dispenser drawer and cleaned? also clean inside of of dispenser opening and upper side
Posted on Aug 22, 2008
Detergent not completely dissolving and small amount of water on the floor
Check detergent is properly inserted. if the tray is not fully in detergent will not dissolve and also water will spill. OR the water pipe may have pushed back.
Dec 08, 2016 | AEG Washing Machines
Tip
LG Washing Machine has an OE error code
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service<br /><br /><b>Step 1: Check the drain pump filter.<br /><br /></b>Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine<br /><br /><b>Step 2: Check the washers drain hose.<br /><br /></b>If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine<br /><br /><b>Step 3: Confirm that the washer is leveled properly<br /><br /></b>If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice-versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confirm that the washer is leveled from side to side and front to back.<br /><br /><b>NOTE: </b>Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
on Jun 02, 2011 | Washing Machines
Tip
Washing Machine Maintenance
Once a year you should take the time to give the washer machine that serves you so well a little bit of tender loving care. This bit of time may prevent you from having washing machine problems in the future. If you can prevent just one washing machine repair it will be well worth your time. While you are doing the preventive maintenance, you also can do a bit of washing machine cleaning as well.
Washing machines are not fun to fix, here are some things that will help you to prevent that emergency repair.
-Check the hoses on the back of the washing machine for cracks, rust or corrosion on the connecting fittings, blisters on the hoses, and or leaks.
-Cracks in the hoses are signs of a breakdown of the rubber and aging
-Blisters are a sign that the water is getting through the inner lining of the
hose
-If your have corrosion then you either had or have a leak
-If left go the hose may be very difficult to remove in the future
-Check that your washer is setting solidly on the floor and is level.
-Out of level and flopping washers can help to cause out of balance
banging, noise, etc.. leading to premature failure of the washer
-Check to make sure that there is no water that drips from the inside of the washer when it is off.
-Dripping water is a sign that the solenoid valve or water inlet valve is
starting to wear and not closing properly. Replace the valve before is fails
completely.
This also is a good time to run your washer through a cleaning cycle. There are different things to use to clean the washer. One of the good old “green” standby’s is plain old vinegar. Dump a cupful in the washer and run through a short cycle. Other cleaning solutions could include things like Clorox, or other household detergents. There also are commercial cleaning products for cleaning washer machines also.
By doing these things once a year you will help to make sure that your washer will give you the best service possible.
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
on Mar 11, 2010 | Washing Machines
OE problem
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Feb 19, 2011 | LG WM2301HW Front Load Washer
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
Im getting an OE error and only use 1 teaspoon of detergent. The siphen hose, next to the filter is completely blocked. how do i clear it?
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.
Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 17, 2010 | LG WM2277H Front Load Washer
Water won't drain out from the spots where fabric softener goes
It typically has some residual water after a load. All you need to do is to remove the detergent dispenser and dump the water out. To remove the detergent dispenser, pull it out as far it will go, then look into the detergent slot. There should be a horizontal plastic tab in the back of the detergent slot. Press the left side of the plastic tab and pull the dispenser out of the machine. Then you can dump the water from the bleach and fabric softener slots. Just slide it back into the machine and your good to go. Hope this helps.
Jul 12, 2010 | Frigidaire Washing Machines
When I turn on the machine, it begins to fill with water. Water then (before the machine would be full) pours out of the tray area where you add the HE detergent. Anyone know a potential fix?
The leak is due to a clogged, small, plastic screen filter located in the cold water hose attached to the back of the washer.
Remove the filter, clean it, place back in hose and reattached hose to washer.
To make the process easier, you can also place a hose filter in the end attached to the cold water faucet so that you don't have to pull the washer so far from the wall.
Check/clean that strainer/filter several times a year.
Thanks!!
1c
Mar 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Oct 26, 2009 | Washing Machines
Lg tromm wm2277hw rinse spin error OE
Oct 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
