Question about Gateway Computers & Internet
The system will freeze, system restore is not working, cannot connect printer, floppy not working. I have tried system restoration kit, nothing has worked.
  • Anonymous Mar 15, 2014
    Freeze
    It just freezes and notering works enter doesn't work
    Scholar:
  • 152 Answers
A little more detail is needed. What is the type of computer - desktop or notebook? What operating system are you using? What are you doing when the system freezes? Does it happen intermittently or only when you are doing something specific? If you can, get all of your info off of the drive that you can. At that point, your best best would be a reformat and a total reinstall.
Posted on Aug 22, 2008
I accidentally deleted connection when trying to get rid of a Built up printing queue! Having done anything manually, only on screen! Help please
Turn off the printer first. Try unplugging the cable between your computer and your printer and re-plugging it back in. Then turn on your printer and hopefully it will allow you to add the printers operating software which is known as a print driver. Good luck !
Jan 06, 2016 | Office Equipment & Supplies
My Toshiba L305-S5907 wont unfreeze
Do a System Restore again but pick a restore point (date) before the troubles began.
Oct 11, 2012 | Toshiba Satellite L305-S5907 Laptop
I have a compaq presario qc60-215dx and the mouse and keyboard will not work. I tried restarting, taking battery out, pressing button above mouse and nothing. I had left it idling earlier and when I came...
Hello.
Most commonly, you either you have an operating system problem or memory issue to cause your system to freeze.
First, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery. Remove the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
Hope this helps.
Apr 12, 2011 | Compaq Computers & Internet
Two days ago, I was able to print documents perfectly. However when I tried today, the pages came out completely blank. I am not out of ink, but nothing is printing onto the paper.
Do a System Restore on your computer. That may reinstall the driver. Restore it to a time the printer was working. If using Windows, Go to start-acccessories- tools. Then down the list to System Restore.
Oct 01, 2010 | Epson Stylus NX105 All-In-One Printer
Restore point nonfunctional
Try turning system restore off and scanning. System resore can hide your problems.
Try this guide http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 10, 2010 | Microsoft Windows Vista Home Premium with...
I have no Acer Recovery disks My lap top is giving me 5 options Systems Repair - tried this doesnt work Systems Restore - tried this doesnt work Windows Diagnostic Tool - tried that took bout ten mins and...
Could you look at solutions other than running a system restore? What is the initial issue that is requiring you to run the restore?
If you're at the point of needing to run a restore, you do need to get your hands on the discs, I would recommend borrowing the discs from someone else with an Acer, or purchasing them from the manufacturer. Trying to borrow discs from someone might be an issue as Acer no longer provides physical recovery discs, the process is run directly from the laptop and the files are on a partitioned section of the harddrive.
Dec 08, 2009 | Acer Aspire 3000 Notebook
How do i put my computer back 2 facyory settings i have no cds t wont do nothing it keeps freezing
can you please check restoration
start>programs>accessories>system tools>select system restore
create a restore point
select any previous restore date
restore in to that date
Oct 28, 2009 | Dell Computers & Internet
Laptop freezes restarts or goes to a blank screen
its not the issue with the system
u have a usb printer connected to the system
disconnect that and start the system it should work
Nov 01, 2008 | Computers & Internet
Acer apire 3000 keeps freezing!
The first, best thing to do is to back up your data and do a system restore. Acer's have the restore function usually built into their acer system management software.
Restoring the computer will solve most issues. If you keep having issues after the restore you probably have a hardware error like a bad hard drive or bad memory.
Be sure to back up any important data as the restore will erase everything from the hard drive and set it back to the way it came from the factory
Nov 15, 2007 | Acer Aspire 3000 Notebook
USB Ports crashing system
If you have done a system restore you have probably restored your problem with limewire also, although what it is that's related I don't know, it's more than likely a dial up or connection problem that is causing limewire to freeze yur system. Check your usb ports in device manager see if there is an exclamation mark or a cross, then refer to this solution for further checks. http://www.fixya.com/support/t125452-another_device_installation_underway
Nov 29, 2006 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
