What if the ink carriage goes into the right corner and won't move to the middle so we can take them out?
Some types of Epson printers, replacement ink tank can only be done when ink reach the zero level or chip level not Recognized. You do this by pressing the button on the printer ink, or by following the procedures in Epson satus monitor. If desired the replacement ink tanks when not in the condition mentioned above, it is clearly necessary to shift the carriage to the replacement position. Unfortunately, the carriage must be locked in parking position. This can be overcome by releasing the lock carriage, or turn on the printer; when the printer initialization (move) from the parking position, unplug the power cord. Then the carriage is no longer locked. Scroll to position the replacement carriage
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4.
Thats it, ink cartridges move to the changing position. Change your
cartridge as you normally would and follow prompts on screen to finish
process.
Hope this helps.
