Question about Panasonic Palmcorder PV-DV52 Mini DV Digital Camcorder
No picture in "camera" aka record mode
Camera was in the closet for a while, brought it out to use and had it say "CLOCK BATTERY". I then charged as the manual says by directly connecting the camera to the charger, DC cord. Left this way for 4 hours.
Then popped in the battery, set the clock time which was blank.
Now there is no picture when recording. The control information such as battery level (full), zoom level, time, etc. show in the display but the picture from the camera is completely black.
Is there a "reset" button somewhere or a "magic phrase" I should speak over it? Or is it a dead camera?
Thanks for help on this!
  • warr8770 Dec 11, 2008
    no pitcher on vcr
SOURCE:
  • 221 Answers
SOURCE: Won't start
how old is the battery? if it's more than 2 or 3 years old, it may not hold a charge. swap a known good battery and see if it works.
Posted on Dec 26, 2007
  • 30 Answers
SOURCE: Can the battery charger be connected to the camera for power?
best bet to deal with the battery replacement is to download the manual from panasonic and follow their guides, they usually instruct you on how to install the button batt ery at initial start up as this is what holds the date/time in memory when you are charging the main operating battery. go to the following link and enter your specific camcorder info: http://service.us.panasonic.com/operman/
regarding the power supply. You need 6 volt DC. but you need to know the polarity of the line feeding into the camera and match that from your power source, if you have the polarity backwards, you can ruin the camera. You can also cause problems if your external supply has too high of an Amperage rating as an excessive amperage can overheat your camera circuits. verify the amp rating of the camera and verify that the VCR dores not exceed that my more than a few amps.
Posted on Jan 28, 2010
SOURCE: dropped olympia video camera.screen has went
The same thing happend to my computer when I dropped it. A friend fixed it, but I'm not sure of what he did. I think it is a cable sending information to the screen to tell it what to show that is broken.
If i'm right, the problem isn't so big, but unless you know something about videocameras, don't try it yourself!
Posted on Mar 17, 2010
SOURCE: Camera suddenly will not record
I had this.
Unscrew the bottom and take off the cover, one of the connections may be loose. Push every cable connection to make sure it's tight. This fixed the problem for me.
Posted on Jul 16, 2010
Rider On Way
  • 1679 Answers
SOURCE: Hi, need help with the camera not powering down
Once you turn off the camera and remove the batter, does it power on and if you press the off button does it go off ?
Try this
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Posted on Nov 27, 2010
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Won't take pictures.
Put a clean sd card in, take lens cap off and turn on
it should work if its not broken.
Aug 08, 2014 | Nikon Coolpix 5700 Digital Camera
Why Fuji Finepix XP20 won't take photos?
Check the settings of the camera. Put the recording mode for stills (photos) to auto, so the setting can't stop the camera from taking a picture. If you are in one of the manual modes, and the system calculates it won't be possible to make a picture (to dark, to light, or out of focus and so on) it won't react when you press the shutter release button.
Please use the manual, so you will be able to solve this every time it happens to you. The manual is still online.
Jul 22, 2014 | Fujifilm Finepix Xp20 14-megapixel 720p Hd...
L820: Display dead in most functions, but not all
I would hope you have tried removing the battery, charging it and replacing it first already. The next thing I would try is to set the camera to factory default options.
Dec 04, 2013 | Nikon COOLPIX L820 Digital Camera Black
Picture display freezes and can't none of features work
PLEASE see the test and fix it. God bless you
1. Camera won't record photos. Make sure you've selected a photography mode with your camera, rather than a playback mode or a video mode. If your camera's battery power is low, the camera might not be able to record photos.
Additionally, if your camera's internal memory area or your Memory card is full, the camera won't record any more photos.
With some cameras, the internal software only allows a certain number of photos to be recorded on a single memory card because of how the software numbers each photo. Once the camera hits its limit, it won't save any more photos. (This problem is more likely to occur when an older camera is paired with a new, large memory card.)
The battery is the root of most common digital camera issues. Though battery life has been extended as battery and digital camera technologies evolve, no battery lasts forever. When your batteries begin to run out, sometimes your camera responds in wacky ways that may not seem connected. The flash may not come on, the autofocus won't engage as quickly as it did before or the LCD screen will power off intermittently. All of your camera's responsiveness is linked to its battery strength. Change batteries and try to recreate a problem; odds are you won't be able to. It's a good idea to carry a backup battery for cameras that use lithium-ion cells or a pack of spares for cameras that use AA. Watch your battery icon for a general idea of
Nov 09, 2013 | Nikon COOLPIX S9300
I have Cannon EOS Rebel xsi. The camera does not take picture when press the shutter in all modes. There is no error message. Have change the memory card, recharge the battery and none work.
Hello Sure !
The probleme :
The Shuteer Has A cable Connected to Recorder
Maybe The cable Has Cutted when you Shut ,or Maybe Cutted When You Charged The Battery cause When your put your camera on the charge , the cable goes be hot and it should be cutted .
Solving The Probleme :
1) I advise You To Change The Cable
2) Push The Reset Button
3) Charge It Again
It works 100%
Fix-shad0w
Aug 03, 2010 | Canon EOS 10D 35mm SLR Camera
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Panasonic Palmcorder PV-DV52 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
