Durst lambda 76 plus. Marks running horizontly on film.I dont know if it si verticle axis
  • Anonymous Jan 17, 2009
    i want to know how assemble and run durst lambda 76 plus ?
    (my email is saint_h77@yahoo.com )
Q lambda76plus Unix Setup time we ate please guide
Posted on Feb 19, 2011
How do i get pantech swift screen from horizontal to verticle?
Have you tried to turn off the Auto screen rotation? Try that and let me know your response.
Regards,
Harry
Supertechnician@outlook.com
+1 (503) 583-2414
Oct 02, 2014 | Pantech Swift Mobile Phone - Purple at&t
Draw a line graph of water temperature vs time
On the x-axis (horizontal axis) represent the time variable. On the y-axis (vertical axis) represent the temperature.
Mar 03, 2014 | Texas Instruments TI-84 Plus Calculator
How do I check if I have marks on the drum of my Canon Laser Printer (LBP2900B)?
If you have marks on your drum there would be repetitive marks every 76mm.
Interval (mm; approx) Roller or component
55 Feed roller
46 Transer charging roller
38 Primary charging roller
76 Photosensitive drum
31 Developping cylinder
57 Fixing film unit
56 Pressure roller
Dec 24, 2010 | Canon LASER SHOT LBP-2900 Printer
My monitor is verticle, won't flip back to
Try to use Cntl+Alt+Arrow keys to rotate the screen. Also go to display settings and change the monitor DPI setting will also resolve your problem.
Thank you for using Fixya.
Apr 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
What are the steps, when given two coordinates to work out the bearing and distance between them
Let us start by setting the terminology right: To locate a point on a plane you need two coordinates ( an X-value and a Y-value). If the point is in space, you need a third coordinate which may be called z, but let's us not complicate things unecessarily.
With just two coordinates, we will be able to locate at best one point.
Let us rephrase the problem: When given two sets of coordinates, how to calculate the distance between the two points.
Let (x1,y1) and (x2,y2) be the coordinates of two points in a plane. To calculate the distance between the points, one uses the formula
d (distance)= square root of ( (x2-x1)^2+(y2-y1)^2)
When you calculate the distance you must substitute actual coordinates for X1, Y1, X2 and Y2.
As regards the bearing, I am afraid that I am no expert in maritime nor in aircraft navigation and I will not venture stray out of my area of competence. However, I know that you need an axis that defines the direction with respect to which angles are measured.
If your reference axis is the horizontal axis on a cartesian plane you can determine the angle that the line joining the points makes with that horizontal axis by calculating its cosine, then extract the arcosine.
If (X2-X1) and (Y2-Y1) are both positive then cos(theta)=(X2-X1)/d, where d is the distance (positive value) calculated above.
Feb 27, 2010 | Casio FX-7400G Plus Calculator
V40 direct injection gdi . rich running & lumpy idle
replace lambda probe expensive but it will run ok after that, i dont know if you know how they work so here's a brief: lambda tells ecu how rich the exhaust gasses are, ecu ajusts fuel input as neccasery eg lambda says not anough fuel ecu puts more in and the other way round.
so if your lambda is covered in **** when you get it out just clean and put it back, if it looks clean enough it needs replacing!! jezza
Feb 09, 2010 | 2000 Volvo V40
2000 renault clio 1.9Dti si timing setting on cam belt
hi from the uk i can scan and e mail you the full instructions and diagram ofbelt timing+marks for alignment plus correct tensioner setting if you send me your e mail address ? best wishes from n/west uk
Nov 25, 2009 | 2000 Renault 181
Brother pr 600 has x axis possition error message.
In most cases customer were emb. bags when or after you get this error message, there is a sensor under the x-axis; horizontal arm; that gets hit and breaks you can try to get a dealer to sell you the sensor and repalce it yourself its really easy, one screw on the side of the x-axis cover and it lifts and slides off and one screw for the sensor plus two flexible flat cables plug into it
May 05, 2009 | Husqvarna Designer I
Proscan PS35123-horizontal line only,sound ok
You have whats called a verticle swep falure. Its probably just the verticle output IC but if you dont know much about soldering or circuit troubleshooting ,you should leave this to the pros. Theres way to much Hi voltage inside these sets to twiddle around inside them. Also there are no consumer serviceable parts inside these sets as well, as they are all solid state, and my advice is spend a few bucks and get a pro to do this job for ya, as it can, and will, kill ya if your not careful.. Is it worth saving a few bucks??? Naawww Call a pro.. Good Luck
Jun 13, 2006 | Proscan PS32600 32" TV
441 people viewed this question
jasbo
jasbo
