Check to see if something inside the control panel circuit board came apart or broke from being moved. These things were not designed to be moved around a bunch so you probably have a soder joint come loose or get disconnected.
so you have power going to the control box but nothing comes on...check the voltage coming out of the transformer. May be that is all that is wrong but may still require a new circuit board.
if you can reach inside the oven the fuse almost beside the power terminals usually like cylinderical shape and it has nominal values wroted on it , must be checked continuity at 1st by ohmmeter
thanks
I take it nothing lights up at all? In the 665 it is very common for the thermal fuse to go out. It should be on the control panel with 2 wires coming out of it with spade terminals. Disconnect that and see if there is continuity
