My external hard drive won't show up and all plugs are connected it is a usb 2.0 1tb
    Scholar:
  • 152 Answers
What brand of external drive? What type of pc? Is the drive compatible with your operating system? Did you install the software that came with the drive?
Posted on Aug 22, 2008
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
My Seagate freeagent 320GB won't show up on my computer. It was working fine yesterday when I backed up some important folders, then later on that day, I went to add something to it, and it told me...
Get the Testdisk app and see if it can identify the issue. You can repair the boot sector or create a new one with th is app. If it shows up in the drive list you have a good chance of getting the drive back.
Mar 06, 2017 | Seagate FreeAgent Pro Desktop - 320GB -...
My computer wont show my hard drive when its plugged in
have you tried connecting the hardrive to some other computer. Is it getting detected on it?
May 30, 2011 | Galaxy Microsystems Galaxy METAL GEAR...
Had to replace my hard drive. Now I need to retrive the information from my external hard drive to my internal drive so all my settings and files show up. Any suggestions?
What kind of drive is the external drive? usb, plug it in to an available usb port. If the drive is some other format like IDE or SATA, then you will need a USB adapter to plug the drive into to easily connect the drive to your computer.
Apr 14, 2010 | Computers & Internet
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Hooking up a
Your external drive has a choice of USB or firewire, so only connect with the USB cable.
Dec 05, 2007 | Western Digital External USB 2.0 80 GB...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
