Question about Gateway FPD2275W LCD Monitor
VGA banner in middle of screen
Every time the screensaver comes on and I later move the mouse to do some work, this VGA banner about 1.5" x 3.0" is in the middle of the screen and I have to manually punch two buttons on the side of the monitor to get rid of it. I have been doing it for about a year and now I'm ready to throw the large Gateway monitor away and buy another product - not Gateway. How do I get rid of this advertisement?
Los draver de audio no aparese de esto monitores son una por que ria
Posted on Aug 23, 2008
I need help about my screensaver, that doesn't work, I have windows 7 and the HP support can't fix it. If I choose any opcion of the default windows 7 screensaver and I prove it with the preview...
There is probably something stopping your system going to sleep. Do you have a cheap optical mouse that creeps across the screen when untouched or a dodgy wireless keyboard and mouse that continues to poll the USB port to keep itself and the PC awake?
Oct 03, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How to get the acer description to quit automatically coming on while computer is idle?
Hello, maybe it's on your screensaver, so to change or disable your screensaver, move your mouse pointer to a blank part of the desktop.
Right-click the mouse button, and scroll down to 'properties'. Left-click on 'properties'. This opens up 'display properties' . You will see some tabs along the top of this box, select 'Screen Saver' and you will see a screen saver drop-down box. Make a mental note of the current settings and try selecting a different one.Then left-click 'Apply' , then 'OK'
Regards,
nicam49
Oct 25, 2010 | Acer Aspire 7520-5185 Laptop
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
My HP Pavillion laptop just started this. I will get up from using the laptop, and when I come back the screen is black and won't come back. Moving the mouse won't bring it back. HELP!
Remove screensaver and sleep settings. And wait for the same duration. It is goes blank and locks up, report again. Else it is a problem with the screen saver. Change the screensaver and try again
Jun 25, 2009 | Dell XPS M1530 Laptop
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Screen Saver no longer runs when Microsoft wireless mouse 3000 is installed.
this is a common problem when using wireless equipment in windows. Especially on Dell notebooks. The PCMService.exe program starts when the computer starts and interaction at some level between this and the Wireless reciever prevents the computer from becoming idle. Therefore, the screen saver and the other idle-related features do not start. this issue may also occur if the PCM and DVDLauncher services are running in the background. This issue also occurs in Windows Vista premium and in Windows Vista Ultimate because of the media center functionality that is built in.
Microsoft reccommends plugging in your wireless device and visiting http://windowsupdate.microsoft.com/ to get the "optional hardware update" named "Microsoft HID Non-User Input Data Filter." This should fix the problem.
Microsoft also reccommends two possible "workarounds" for this problem if you do not want to install the update or if the update does not work, both are relatively simple:
1- turn off the PCMService.exe program. to do this, first you open the system configuration (start->run->msconfig.exe). on the startup dab of the configuration window, click to clear the PCMService startup item check box. Apply, Close, and if/when prompted, restart your computer.
2- Remove the PowerDVD Software (not advised if you use this software for watching DVD's on your notebook). To do this, open the add or remove programs window (start->run->appwiz.cpl), locate PowerDVD, click change/remove, and follow the steps through for removal of the program.
Jun 30, 2008 | Microsoft Wireless Notebook Optical Mouse...
FPD1775W
Use these steps
1. Rightclick on the Desktop
2. Click Properties
3. Click ScreenSaver Tab
4. Click Power
5. Turn on Monitor - Never
6. System Stand by - Never
7. Click Apply
Thank U
Apr 16, 2008 | Gateway FPD1775W Monitor
Microsoft 3000 wireless mouse problem
Normal 0 If you are using Vista Operating System this is a common problem.
!. Go to MY COMPUTER and RIGHT CLICK on it.
2. Then CLICK on PROPERTIES.
3. Next CLICK on DEVICE MANAGER. 4.Next CLICK on CONTINUE..
5. CLICK on the HID HUMAN INTERFACE DEVICE +.
6.Right CLICK on the HID NON-USER INPUT DATA FILTER.
7. Click on UPDATE DRIVER SOFTWARE. 8. When the screen comes up CLICK on SEARCH AUTOMATICALLY for UPDATED DRIVER SOFTWARE.
When finished the screen saver should work properly. Bud
Feb 21, 2008 | Microsoft Wireless IntelliMouse Explorer
Internet & mouse
check the BIOS if the USB support is enabled. check also on pointing or pad device that is also enabled.
Jan 23, 2008 | Acer Aspire 5610-4648 Notebook
Gateway FPD2275W LCD Monitor Logo
137 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
