Question about Lands Phones
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
  • jtmoore Aug 24, 2008
    The handset fails to connect to incoming calls. You can be right in front of the base set and it comes up "out of range". The line is very crackly.
    Have checked all lines. Would reregistering the phone help? - have lost the manual.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Posted on Mar 03, 2009
Delete incoming call log?
1 Press Cid when phone on standby
2 Press Menu/Select
3 Select DELETE ALL
4 When phone asks you to confirm select YES
Apr 25, 2014 | Uniden DECT 6.0 Cordless Phone
The answering system status shows the lette ' A' but not nunbers
With many Uniden cordless systems the letter "A" indicates that the machine is in announce mode, which plays an outgoing message but does not record any incoming messages. If you want the machine to record incoming messages then you need to switch to the answer mode.
Since you didn't specify the model of your Uniden cordless system I can't tell you how to switch modes. I can suggest you select the model of your system from the list beginning here to download a copy of the manual.
Feb 18, 2013 | Uniden Cordless Phone
Need owners manual
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 07, 2010 | Uniden 5.8GHz Cordless Phone
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
Cannot make out going calls.
;change to pulse from to tone. Addressing with uniden and my phone co.
Jan 06, 2009 | Uniden Cordless Phone
Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
Bobby@welleasy.com
see for more info. http://www.uniden.com.au/RESOURCES_MAIN/pdfs/ELITE8805_OM.pdf
Jan 21, 2008 | Uniden Cordless phone EXS9950
Lands Phones Logo
887 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
