Question about Saeco Incanto Classic Espresso Machine
Rinse cycle won't stop
I have a Saeco Incanto Su[ 021 YDR. This morning as it started up the rinse cycle won't stop. I have tried turning the machine off, leaving it for a while and then starting again and it just goes on rinsing - if I leave it it keeps rinsing until the water needs refilling which I do and the rinsing then continues.
  • 515 Answers
Start rinsing again, when the water comes out, take off the water tank and let the machine go to it stop.
/Mirran
Posted on Aug 22, 2008
SOURCE:
How it works decalcing, saeco incanto de lux
from the menu select descaling and open the steam knob. The machine is doing descaling.When descaling proces finish fill the water tank with frsh water and rinse from the hot water .When water finish you are ready to drink coffee.
Jul 04, 2014 | Saeco INCANTO DELUXE Espresso Machine
How to decalcify
Make a solution of ½ pot vinegar and ½ pot water.
Run a cycle thru the machine. If there is a cleaning function on the coffee maker, use that.
If very calcified, run a newly made solution thru again.
Rinse by cycling fresh, plain water thru, 2 times.
Jun 16, 2013 | Saeco INCANTO DELUXE Espresso Machine
I have a saeco incanto classic I have tried to descale 2 times and the red light will not go off, is there a reset buttton?
Hi
In order for the light to go off, the machine has to stop pumping on its own, both in the descale and the rinse mode. If you stop it before its done it will still be in the descale mode.
Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
May 04, 2010 | Saeco Incanto Classic Espresso Machine
English manual for a saeco sup 021 - decalcifying
You can download it from this link:
http://www.gaggiaparts.com/user/Incanto%20Classic%20MANUAL%20USA[1].pdf
Nov 14, 2009 | Saeco Incanto Classic Espresso Machine
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto
Hi
Jul 01, 2009 | Saeco Incanto Classic Espresso Machine
Rinsing the incanto
If you will clean it after using a preground coffe, open the door and take out the brewing unit (central unit) and wash it in warm water instead.
Make sure to descale your machine regularly.
Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
SAECO SAECO INCANTO DE LUXE
descaling it with special produit not vinegar 1 part descaler 1 part water put in water container start machine open water valve for few second leave it for 15 minute repeat untill empty rinse very good cheers
Jan 21, 2008 | Saeco Incanto Classic Espresso Machine
Water leak
The majority of leaks in the Incanto are caused by the steam / tap body installation. If you open the machine, you will find the tap body is made of toughened plastic. This is inferior, and should be replaced with a brass tap body which can be purchased directly from Saeco. Also, the piston sometimes sticks and creates a blockage. You will also notice the steam outlet is only cm's from the micro processor on the power board. Any leaks from the steam tap body almost invariably wreac havoc on the power board. Overall, the Incanto is a poorly designed machine that I would not recommend.
Nov 10, 2007 | Saeco Incanto Classic Espresso Machine
Decalcify
when the machine gives the signal press the bottom right hand button for 5 seconds.
it will tell you to open the knob.
before you open the knob fill the water tank with the descaling solution
place a large water receptacle under the steam wand.
now turn your knob
the machine will start to descale this can take a while
when the descale cycle is finished close the knob.
rinse the water tank out with fresh water and fill it will clean drinking water.
Press the same button on the bottom right to confirm that yo are doing the rinse cycle.
open with knob and the machine will start the rinse cycle.
when the rinse cycle is complete close the knob and load the circuit.
when descaling is over fit a new cartridge filter in your water tank and off you go with your descaled cleaned coffee machine.
May 21, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
1,471 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
