Can't connect to home hub
I have a SITECOM Wireless Network PCI card 140g+ installed on myPC and i cant get it to connect to my BT Homehub can any one help??
  • 60 Answers
First, check if your networ adapter is installed properly by opening your device manager. if it is there and does not appear with any marks or splats like a question mark or exclamation point, you can close that window, check if wireless zero config (if you have WinXP) or wireless auto config (if you have WinVista) in Start> Run> Services.msc (XP) or Start>click on search field and type in Services.msc and right-click on that item and choose either Start OR Restart. close that window . (on WinXP) open network connections in control panel, right click on Wireless Network Connections>Properties>click on Wireless Connections tab, place check mark on Use Windows to Configure Wireless, click on OK, that will close that window. then right-click again on the Wireless Network Connection and choose View Available Wireless Network, your network should be there now. on vista, just simply look for the "two computer" icons in the system tray at the bottom right near the time, right-click on that and choose Connect to a Network, it should be able to find your network from there.
Posted on Aug 25, 2008
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
I can't connect my kindle to my homehub. How do I find the hub password or re-set it?
if this is a bt homehub then the password for the wireless is on the hub on a sticker that says security key or network/WEP key, you will also have to press the hub button to allow the kindle to connect
Mar 28, 2011 | Computers & Internet
My Sitecom 300N repeater resularly loses its connection to my BT homehub. I think this is when the H homehub goes down sometimes. Resetting the Sitecom from scratch is a pain but resolves the problem. 3...
I also had this problem when the BTHomeHub goes down, power loss etc. I seem to have fixed the problem by changing the wireless config in the homehub to use a fixed channel, (the default is automatic which means it changes each time it restarts). This has been running trouble free for a couple of weeks through a number of power outages.
Can't help with Qs 2&3, get the same problems but less of an issue now that the thing works all the time.
May 16, 2010 | Computers & Internet
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a Sitecom WL330 wireless repeater
Hi I'm having the exact same problem with a Sitecom WL330 and a BT business hub. Just get unidentified network when trying to connect. Did you resolve your problem? and if so how?
Jan 16, 2010 | Computers & Internet
Cannot connect to BT Homehub at all and therefore cannot access itunes, safari etc.
My Ipod touch would not connect to Bt Home hub.I reset hub and tried again and when it asked for password i entered Wireless key code found on hub Bingo worked fine since.
Silver Surfer
Jan 11, 2010 | Apple iPod touch
Cant get it to connect with my bt home hub
press the wireless key on your homehub first then it will allow it to connect, this only needs to be done once
Dec 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
How can I make my canon mp140 wireless? I have a BT home hub on a secure network and it has a USB port, Is is possible to make this printer have some sort of wirless capabilities so i canb print from...
Its not an offical part of the homehub, but connect the MP140 and the HomeHub by USB, then on the computer you need to tell the PC that the printer is attached to the homehub rather than the PC. So on windows, start the add new printer wizard, and follow the steps on
Dec 11, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Cannot connect printer to a home network through BT Homehub 2
Probably going to have to go to Lexmark web site n download the drivers for that printer.
May 03, 2009 | Office Equipment & Supplies
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Computers & Internet Logo
221 people viewed this question
David Payne
David Payne
