Question about Sony Playstation 3 (PS3) Console
Video/Audio problem My 40 GB PS3 was working fine for the first three days after purchase, but now the picture and sound don't appear after it is turned on. The problem wasn't with the AV cables or the HDMI cable, but with the system itself.
  • 2 more comments
  • reeree2 Aug 23, 2008
    I am connected with an hdmi cable I can play the games but I can't get a audio sound no sound at all
  • Anonymous Aug 23, 2008
    playstation 3 does not show anything on screen with da av cables
  • kwake06 Sep 05, 2008
    One day I was playing my PS3 over a friends house and he had his PS3 attached to a HDMI cord. When we decided to switch and play on my system with the HDMI cord, it worked fine, but when I got home to plug the AV cable back to my PS3 it did not work.
    The Audio and Video no longer was able to work. But, when I went to the story to buy a HDMI cable it worked fine.
    Since I have a TV without the HDMI capabilities in my apartment I need to use the AV cable.
    I went out and bought a new av cable from game stop and it still does not work. What should I do?
  • Anonymous Nov 27, 2008
    I have had my PS3 for about 2 and 1/2 years no problems then all of a sudden i go to turn it on and get no sound no video. I know it is powering on and I can turn it off with remote becouse i remember the buttons to do it with. But the screen is black.
  • 33 Answers
PS3 is The amazing device by sony but it has some common problems like sound , video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog.
Posted on Mar 06, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Oh you should have no problem at all, get a new ps3 with your receipt,that does'nt make any sense,
Posted on Aug 22, 2008
SOURCE:
I have a cable box connected to reciever and was working fine for months, now i get no picture on tv only sound. I use hdmi cable out to tv that also uses my ps3 to tv which is working fine. What...
I don't know what kind of TV you have and what kind of output capabilities you have but, while your receiver will transfer your video signal, it is not the ideal way to hook it up. The port you are using may have to be reset somehow or, may have gone bad. Ideally you want to hook all video componenets directly to TV then, use, digital optical is best, audio out from TV to receiver. If you have more than 1 input in to TV, you can run your PS3 and cable box directly to TV, using the TV's menu to select which you are using, then, run your audio out to receiver.
May 23, 2011 | Denon AVR-887
Used PS3 40 GB works fine at the home theater company I purchased it from. Brought it home and I get no output at all. Took it back, they plugged it in and it worked fine on thier equipment. Once again I...
While the system is off, hold down the power button. You will hear one beep, keep holding it. You will then hear a second beep and it should turn off. Now turn it back on, and the video settings should be reset.
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Av cable displays no video but only sound
Use your ps3 warranty and get Sony to replace that one with a new one.
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Ps3 restarts itself (when it does work nothing on screen)
sounds like your ps3 has overheated. ask a good electronic repair shop to change the thermal compound between the cpu/gpu and the heat sync. let them know the gpu and cpu may need to be reflowed.
Tip: Keep your PS3 flat do not store standing on it side this will help prevent the thermal compund from moving as much
May 08, 2009 | Sony Playstation 3 (40 GB) Console
No picture, only sound through HDMI port
You have the video [yellow cord] on the wrong rca jack. Or a bad video cord. Should be easy to fix.
Mar 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Problem with Picture and sound after about 40 mins playing time.
the unit is over heating. Make sure you hear the fan come on. Also make sure the unit is in a spot where it gets ventilation. They get real hot and need to disapate heat or the mother board burns out.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Got picture no sound on games only
Check the audio settings on PS3 and make sure they are set to what audio source you are using. If not that make sure those inputs work with other devices. If not that then the sound card has gone out and the soon the video car will go out.... :(
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Sound and picture would not work
PS3 is The amazing device by sony but it has some common problems like sound problem, video/picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Oct 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
