Question about GE Spectra JBP78 Electric Kitchen Range
Cracked glass top
After the "hot" lights went out, I began to clean the top with proper cleanser and I heard and saw it crack from one of the burners.
  • ajbertheau Aug 22, 2008
    What might have caused such a thing?
  • Anonymous Aug 27, 2008
    We have the same thing, same way it happened. Now we have several more cracks. The Ge smooth top is only 3 years old.
    I can't find the warrenty, but I doubt we have any recorse there.
  • 1,543 Answers
Your crack was most likely cause by a flaw in the glass top. Most GE smooth-top ranges (espesially if manufactured prior to 1/1/06) have a five year warranty covering this type of failure. The labor is not covered after the first year. Check the back pages of your use and care book for warranty info on your model. I'd advise against continued use of the cook top with a crack, as spills can get to components and cause further damage.
Posted on Aug 31, 2008
May I cook on the rounds not cracked when the stovetop glass is cracked?
Hello;
My name is Peter. I am a retired field service appliance technician.
First, go to Lowe's or Home depot. Purchase a electrical tape rated for 700 Degrees F. and seal the crack.
Second, you want to make sure no fluid or what ever gets into the crack. This will knock out your heating element and burner control.
Third, You can use the other burners. The temperature may be a bit higher than the burner control indicates.
Fourth, Purchase a new glass top. There are only a couple of screws that hold it on.
Fifth, Go into the following web site. Put in your model number. This should be on a metal plate after you open the oven door, on the face of the unit. Plug in your model number.
Sixth, On the diagram on this site locate the part number for the glass top. Search the internet for best price.
Water Filters Lawn Garden Appliance Parts
Mar 14, 2015 | Kitchen Ranges
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
Apr 12, 2009 | Whirlpool Accubake RF362LXTT Electric...
I have a GE profile Glass top M#JSP47COF4CC That is cracked but can't figure out haw to remove. Have already removed 4 screws under control panel still won't budge
To remove the top on this range, remove burner knobs and face plate, then remove 2 screws from control panel one at each end. Fold panel down out of the way, remove 5 screws accross front of control panel and release 2 quick connect plugs for burners, then lift to remove glass top. Flip over remove 2 screws and clips from each burner and the indicator light assembly just pops out. Transfer this to new top and reverse your steps for removal.
Mar 27, 2009 | Kitchen Ranges
Pilot light to oven went out
It could be that the safety ($150 to $250) is getting old, or grease filled. It could also mean the thermocouple ($7 to $12) is going bad, or has a bad connection. If the copper jacket of the thermocouple is blackened near the pilot, broken or cracked in anyway, it may not be working properly, as it generates a small voltage when heated, less than100th of an AAA battery, to keep your pilot lit. If the pilot orfice is clogged with dust it produces a smaller, less hot flame, which also lowers the output of the thermocouple. If I was performing the service, you would automatically get a pilot cleaning, and a thermocouple, the safety could still be bad, and confirming this is a 50/50 chance to begin with, but it is a cheaper start. Good luck, ask more if you need too, thank you, an Happy New Year.
Dec 27, 2008 | Garland H283 Gas Kitchen Range
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
KERC600GWH1 glass control panel is cracked.
Replacing the Ceramic top is not difficult. Just remember to be careful. There should be 2-to-5 screws holding the top to the front support. Removing these screws will allow the top to be tilted up and back. Depending on the style you may have to remove the burner plates from the top. Remember to disconnect the power before attempting any repair
Oct 22, 2007 | KitchenAid KESC300 Electric Kitchen Range
Igniter
It is normal for all 4 burners to spark at same time.  Often burners won't light even when you can see the spark at them because the burner is dirty.  Take a pin and clean out all the holes in rim of burner.  Also look for small cracks in white part of igniter.  If cracked it must be replaced.
Oct 21, 2007 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
219 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
