Question about Toshiba 43H71 43" Rear Projection Television
More on signal board jumpers
Thanks for the quick response. So these are wires in parallel with the traces for better current carying? I see an inductor and 4.7k resistor in the +/-16v paths to the STKs, but no jumper wires near the STKs (actual board is back in the set right now). If this is something I need to add, what do the numbers you list mean? Where should thes jumpers be connected - are there specifics posted on another thread somewhere (I tried to search)? Thanks!!!
(By the way - I have just replaced my STK's, but F850 in 16v path continues to blow.)
  • hobbystuff Aug 24, 2008
    I used genuine Sanyo STKs.
    With the board out of the set again, I was able to identify the jumpers as described (thanks for your patience!). 010 did have a broken solder joint! I then replaced F850 and 852 on the power board and everything comes up - Yea!!!
    I went into the convergence service menu and re-aligned the grid. But at the end, I get "Touch Focus Error". Any thoughts? Picture looks fine. Thanks!
    Genius:
  • 1,694 Answers
I will try my best to explain.....hard wires connect two circuit
traces together and are not in parallel with any component.They are used where a component is not needed.....however, the 16v
supplies must travel from the main board where the F850 &F851 fuses are to the signal board where the STK's are....after the two B+ volts pass thru the two PCB edge connectors,typically on an "H" line Toshiba en route to the STK current limiting resistors there are hard wire jumpers with NUMBER locations marked on the PCB.Just " Follow the path the voltages take" & solder all connects.......
Next thought = What brand / quality / price were your new,replacement IC's ?? = Toshiba,Sanyo or.....Chinese junk?
..........................T.
Posted on Aug 22, 2008
  • Vista Electronics Aug 24, 2008
    Touch Focus Error means convergence in servicer mode is not
    adjusted tight enough......if pix looks good to you I wouldn't worry about it........as-is will not harm set............. T.
Fuse 18 for dash lights keep blowing. Have replaced light switch and instrument cluster
If your fuse blows repeatedly, the circuit is drawing
too much current. Possible causes:
1) short in circuit... frayed wire, accidental circuit board contact with metal frame, solder bridge on circuit board, or wire placement/connection error
2) Too high voltage in circuit can cause excess current
drain
TROUBLE SHOOTING: measure circuit voltage w/ meter. If normal, put amp-meter (with fuse) in circuit
at problem fuse connector and quickly check current.
If very high, trace (look) along current path for location
of a short to ground/frame/etc.
Hope this helps...if this is all Greek, consider looking
for Better Bus. Bureau approved repair shop.
May 06, 2013 | Rotora 2003 DODGE RAM 1500 PICKUP...
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
No combustion motor on call for heat. or no ac. this is with tstat disconnected and jumping wires at unit. board has been changed and there is power to the board. there is 24 volt at the stat connecting...
If the blower is not responding when you jumper R toW and R to Y that is because G is the blower signal.
Put a jumper R to G and Y
Then R to G and W and the blower should work.
Oct 14, 2009 | Heating & Cooling
I have had the fuse to the fuel pump blow so i replaced the pump and it still does it . so i unpluged the pump and the fuse still blowes
The problem is not the pump but in the wiring. The sensor is connected in series type(remember in school -- series and parallel) and thus is being fed higher current and/or voltage from the battery. Its the wiring which is clamped together. Examine by tracing both leads to the battery. Its insulation must have melted and come in contact with another wire which caries higher current. The fuel pump gets activated the moment you turn the ignition key 2 notches, i.e., the dashboard lights starts glowing and thus turns on the electric circuit in which the pump(fuel) is an essential gadget. So check the wiring thouroughly including the ignition key terminals.........................sodeep
Oct 02, 2009 | 1988 Pontiac Bonneville
Dell HK 395 Speaker System - Need Circuit Diagram Download
1.  Check the orange multi-pin connector the sufwoofer for a broken or bent pin.  If there is a broken pin you can bypass it by cutting open the cable jacket and tap onto the affected wire with a 6 inch or so jumper, and then attach a jumper to the appropriate point inside the subwoofer.  Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
2.  Try wiggling and rapidly rotating the volume control.   There are reports this control may become a problem as it ages.
3. I haven't been able to find a schematic.  My only recourse was to google the output amp and the 2 op-amp packages for data sheets.  They are readily on the internet.  Then I laboriously traced out the stereo paths.  I found that red and black fine tip felt pens were helpful in marking out the signal paths through the circuit boards.
Nov 21, 2008 | Dell HK395 Computer Speakers
Signal board jumper wires?
Hard wire jumpers feeding voltage to convergence circuitry located between board edge and current limiting resistors & near STK IC's.................HTH........................T.
Most H-line Toshiba's have them......
Aug 21, 2008 | Toshiba 43H71 43" Rear Projection...
Best wiring method
Actually, the way they're wired they're already bridged in parallel. The way they're "jumpered" They all get the same amount of voltage and pull more current from your amp. If you wire them in series, each speaker only gets 1/3 the input voltage, and in turn, the entire circuit of 3 speakers uses less current from the amp, meaning less wattage. Having them wired in series will cause less wear and tear on your amp, but you'll not be pleased with the output. It'll be very weak. Try it. You'll notice the difference right away. The way they're wired is the way they're probably supposed to be from mtx, and the speakers probably have a higher resistance, which means they work best when bridged parallel in threes. Your amp is already taking all the punishment thease speakers can suck through it in this setup. If your amp is running cool, you shouldn't have any problems. Hope this helps.
Nov 28, 2007 | JVC CS-HS601 Car Mid-Range
Samsung TXK2754 27" main board cracked after fall
You would have to contact the manufacture. a better solution would be to take it to a shop and have them repair the board. It would involved using acitate glue and the bridging the wire traces back with wire bridges (jumper wire soldered to the traces). If you are not able to do this on your own a local shop could do the job.
Sep 19, 2007 | Samsung TXK2754 27" TV
Missing part
Hi, Sorry to tell you but this motherboard supports ONLY SDRAM memory. There is no way that a DDR memory will fit into this motherboard. What you can do is add another SDRAM memory for better performance.
Apr 28, 2007 | Syntax SV266A SKA KT266A Motherboard
Toshiba 43H71 43" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
