Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30 Thank you for your help earlier. I figured out a way to get the machine running on 220. Now my problem is finding the intake for the sanitizer and detergent. I have looked all over the machine and I cant find tubes anywhere. The guy I bought it off of tells me that when the water temp is over 170 you don't need any cleaning products. I just want a second opinion. I feel that our glassware is not as clean as we would like. Any thoughts?
  • 38 Answers
I'm not sure I'm comfortable with the direction your seller is leading you. I assume this machine is installed in some type of place where you are serving food to the public. If this is the case, then the local health inspector will expect to see a wash tank temp of 150F-165F and a rinse temp of 180F-195F.
With a wash temp of 170F, you risk a health violation for over-temps and this can also cause so food soils to get "baked" onto the wares. With a rinse temp of 170F the health violation is under-temp and you likely will not have good sheeting/drying action on the glasses, leading to a spotting issue.
Hobart sells this machine with an "optional" kit for external chemical dispensing, but if you have the base-model (which it sounds like you do) it does not come with any type of ports for chemical injection. If you are truley concerned about consistent, pleasing results, ie clean dishes, no spots, etc. Then it would be my advice to have Hobart install this kit, and then contact a local chemical supplier for proper chemistry (a detergent and a rinse additive) and balancing of the machine. Most chemical companies do not charge for installing their needed dispensers onto your machine, and do not charge for service calls. They only charge for the chemicals you use. I have a personal preference towards Ecolab, but that's just me...
If I am way off on this, meaning you're not serving to the public (just your family) and a health inspector would never see this machine, then just get some cascade and call it good...
I hope this helps and please let me know if I can be of any further assistance,
Kermit
Posted on Aug 22, 2008
I have a Hobart Dishwasher model LX30, it seems to stall when in the fill cycle from the start, which blocks any further function except shutting down, on the screen there appears a wrench insignia.
Hobart LX30H ML 104354 Manual Page 28
According to the manual ... the wrench icon comes on with OTHER codes for the LX30. Did you get a flashing P1, P2 or P3?
Or for that matter, get any associated E codes to come up?
Depending on the P or E codes there are fixes discussed on prior Fixya answers for this machine ... search there for more help
Mar 05, 2018 | Hobart Dishwashers
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Our hobart machine just shuts off and wont come back on again. All the lights go off.
always put mod#, ser#, and ml# when stating problem, sounds like the switch membrane is bad. hopefully your dishmach. is an lx18,lx30
Dec 28, 2009 | Dishwashers
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 | Dishwashers
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Aug 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Jun 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart fx25 dishwasher
I think you may have the wrong model number of the dishwasher.I work for hobart but i dont recall a dishwasher with the model number you givin me.Look on the data plate again some examples of hobart dishwashers are--sr24---am14---c44---c44a---lx18--lx30--lx40---lxi---uw50--sm6t2.Once you find the model goto this site and you will find a manual.any other questions let me know.http://www.hobartcorp.com/default.aspx
Nov 22, 2007 | Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
310 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
