Question about Hoover Vacuums
I think I picked up a nail with my Hoover Legacy Two, Vacuum Cleaner. It made a terrible sound and i sh ut it off immediately. I can't locate our manuel. How do I get into the propeller area, to extract this nail?
I removed the plastic tip of the suction adjustment lever, and then easily pried the plastic housing covering and protecting the motor. Once the motor was exposed one could see the 1.5 inch screw, quite easily. With a pair of vise grips the screw, with some difficulty, was extracted from the fan wing. I replaced the housing and found the vacuum cleaner worked as well as before. I applied goop to the lever tip, put it back where it belonged, and allowed it to dry overnight.
Posted on Aug 24, 2008
Why does water pour out the back when I use carpet steam cleaner
Hey there! It sounds like your cleaner is leaking. That can mean an issue with your pump assembly. We recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jul 01, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
My hoover legacy steam cleaner model#f7223-900 keeps dispensing liquids. Any cures woul'd be helpfull. thanks-
This model has electric solenoids which dispense solution. one may be stuck open, I would recommend to take it to a service shop for an estimate.
Mar 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I think there used to be a metal hanger-like piece of **** holding down the bag at the spot where it is affixed to the vacuum cleaner. I want to find it, and if possible, download the **** manual. Too much...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559223 Generic problem for all Vacuums I think there used to Posted by imaninvisibl on Apr 30, 2008 I think there used to be a metal hanger-like piece of **** holding down the bag at the spot where it is affixed to the vacuum cleaner. I want to find it, and if possible, download the **** manual. Too much to hope for? Hoover Legacy 830.....Model # U5079-910......Serial # 069100005664. Please don't tell me it's SO old they deny ever having made the thing! Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Legacy 830 – Model #U5079-910 The vacuum model is not that old and I would suggest that you contact your local vacuum dealer to see if they have a new or a good used metal piece that would work or contact the Hoover Co and they could send you a owners manual or instruct you to download the manual from the Hoover website. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.hoover.com Telephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS. Don – The Vac Man Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Vacuums Logo
48 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
