Question about IBM Netfinity 5100 8658 Server
IBM Netfinity 5100 8658 Server Problem
I have a flashing CR56 and the computer will not boot the fan will run but nothing happens
Chang it to an alpha server, you are in US.
Posted on Sep 18, 2008
IBM server x3400 not starting
This is a Planner issue (Mother Board) . Open side cover and investigate capacitor status . Probably some capacitors are bulged . Check it and replace if necessary .
Good Luck
May 16, 2012 | IBM x3400 Server
Netfinity 5000 bios password unknown - I got a IBM Netfinity 5000 for free from my schoo and they had a BIOS/Admin password set. The school hasn't used these computers for a long time so no one knows...
****. IBM just wants your money. In most cases, the bios password can be disabled by removing the CMOS battery. Remove the CMOS, pull out the power cord, and hold the power button for 10 seconds to drain any residual charge. Boot the computer without the CMOS and it should say password disabled. Turn it off, unplug it, and slap it back together. You should be fine. Let me know how it goes.
Aug 06, 2011 | IBM Netfinity 5000 61Y (865961Y) Server
At bootup, I receive a message about a problem
Turn the computer off.
Remove the RAM from that J1/Slot6 slot.
Reconnect the power and start it.
Do you still get the "problem" message?
Mar 26, 2010 | IBM Netfinity 5500 M20 4RY (86624RY)...
Problem woth IBM netfinity 3000
You definitely should be able to boot from cd. I used to have a netfinity 3000 and regularly booted off cd. However, there are 2 possibilities here:
a. your cd-rom is faulty
b. your cd disc is seen not bootable
I would suggest checking whether you can boot from this cd disc on another machine-if so, I would try swappin cdrom in the netfinity.
Good luck,
Raf
Nov 08, 2009 | IBM Netfinity 3000 80U (847680U) Server
Netfinity 5600
It is certainly not ok for it to take so long to show bios.
This usually means there is a hardware conflict at low level (not a broken part)
This can occur if there is more than one disk that it has to look at that it cannot work out (this may be in your case)
you may want to start the system with only one disk in and get i runing from there before adding extra storage.
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-45350
May also be of help to you.as may
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MCGN-424RDV
You did not say which OS you were intending to install but thee is plenty of documentation for that around
If this information was useful please click
Aug 14, 2009 | IBM Netfinity 5600 8664 Server
Boot Problems... Complicated...
The IBM Netfinity 5600 is a complicated beast for sure. You really need to get a copy of the Netfinity Manual from IBM (not on the web site fyi.). It's as big as the machine unfortunately. In section 3, p.124 it lists 3-3-3 beep code as "No memory has been detected in the system" solution is "Reseat mem modules or install mem modules. If prob persists get machine serviced." On the previous page, 3 short beeps (only) on POST indicate "system mem error. combo only occurs when video bios cannot display error msg. replace the failing mem module." You might also want to check the light-path diagnostics inside the machine. A little light will be illuminated right beside the bad DIMM.
Jun 06, 2008 | IBM Netfinity 5600 8664 Server
IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
http://tinyurl.com/5fmv5k
Sep 21, 2007 | IBM Netfinity 5600 8664 Server
Bios upgrade error
re-install the old bios. evidently the new flash bios is not compatible with your machine.
Sep 11, 2007 | IBM Netfinity 5500 M20 4RY (86624RY)...
IBM starting problem.
Hi , if your dont have any data, try to get the IBM Netfinity CD for 4000r which supporting the OS 2003. Usually IBM provide a cd on each NEtfinity server. Check on the IBM website for more details about your Server Compatibility on 2003 server. then proceed to re-intalled the OS.
Aug 10, 2007 | IBM Netfinity 4000R 8652 Server
IBM Netfinity 5100 8658 Server Logo
215 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
