Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore portable washing machine won't drain all the way
Water does come out thru out hose but not completely what to do?
  • 550 Answers
Most common cause is there is a sock or other small item in the inlet hose from the drum to the pump, restricing water flow and the normal time allowed in timer cycle is not enough
open the cabinet as described elsewhere, I am just too laxy to type it at the moment.
examine the short hose from the drum to the pump, and unblock it
Posted on Oct 18, 2008
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My washing machine won't drain water.
Click this link below and go through the test procedure :----http://howtobyme.blogspot.com/2011/09/how-to-check-drain-pump-on-kenmore.html
---------This will help.Thanks.
Jan 28, 2012 | Washing Machines
Washer is full of water. drain is blocked with hair or lint i believe. washed some nasty stuff. wont drain. how do i clear the blockage? i think may be blocked inside washer. drain hose is very narrow...
If you can get a garden type water hose near there, try to carefully use it to blow the water backwards through the drain hose. Put the hose up to the drain hose end and wrap a rag tightly around it and turn the water slowley. This may free up any debris from the hose and pump. If anything comes out,clean it out of the tub before you turn it back on.
Sep 02, 2011 | Kenmore 2.1 cu. ft. Portable Top Load...
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine never fills. The water keeps flowing and goes right down the drain... So it just stays stuck on the fill cycle... what do I do to fix it?
Have you checked the locatio of the drain hose?
Sounds like the drain hose is lower than the top of the tub and the water is running thru the pump and out the drain hose (water seeking its own level).
Mar 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
HOSE PARTS?
If you mean external hoses between tap and washing machine, and washing machine and waste drain to install the washer in place. Everywhere. even the local hardware store, those items are a standard size, thread, and diameter and fit all washers.
if you mean the click fit hose to a sink tap, with the waste water drain buldled in so the washer can remain portable
Sears has them as a to-order item and most parts stores will have a generic brand that will fit straight on, the screw fittings are standard.
Aug 08, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
624 people viewed this question
Sal De
fordexpert
Robert Rankin
