Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Dishwasher doesn't clean dishes
i turn the DW on, it runs and beeps when done. i open the door and everthing is wet and the soap is gummed up on the door or at the bottom of the DW. dishes are not clean. what may be the problem and what do i do to have it fixed? thank you, carol
    Sergeant:
  • 409 Answers
Hi carol,
sounds like the d/w does not run through the rinse and dry cycle. do you have a timer on your d/w or a digital display?
Posted on Sep 13, 2008
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
I have a maytag mdb5130 that the soap is caking in the dispenser so not going out and cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 17, 2011 | Maytag Dishwasher
After running, I open up DW and find all the soap lying in the bottom of the dishwasher by the round thing directly below the soap cup. Is the door opening up early and letting all the soap out? Am I...
Dishwasher
How to Buy
heatman101
Asker
Apr 13, 2011 | Dishwashers
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Dishes aren't clean, yet there's still soap residue in the cups
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
May 09, 2010 | Frigidaire 24 in. FDB635RF Built-in...
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
The dishwasher does not drain and the soap door opens but we are left with just a big clump of wet soap in the cup.
If the DW does not drain the pump could be clogged or has failed. That would also cause the spray arms not to rotate and not circulate water to dissolve the soap or clean the dishes
Aug 26, 2009 | Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dish Washer soap does not dispense during wash
You don;t list the make and model number or its aproximate age.
The simpelest cause is switching to an ultra-cheap dry detergent. Recommed you use a name brand powder (like Electrosol or Cascade) Never use gel or tablets, ever.
Check all spray arms for blockages. Now is a good time to remove the filter (non trivial but do-able on most dishwashers.)
Clean empty dishwasher by filling a bowl or large cup with white vinegar and placing it in the dish rack. Run a short cycle with no detergent added. You may need to repeat.
If problems persist, the pump motor is probably failing. Schedule a service call or consider replacement of DW. Good Luck!
Mar 29, 2009 | Dishwashers
Detergent compartment not emptying
If your getting water while running and the soap is turning into a solid in the soap compartmetn, try running hot water at the sink before running the dw and use all the heat hot water settings on your machine.
If this doesn't help please give a more detailed description of your problem
Feb 08, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
97 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
