I purchased a Dazzle DVDRecorder to convert our home 8mm tapes to DVD's. It seems simple enough. I plug the sound cables & video cable into our video camera and then into the Dazzle. I put the Dazzle USB cord into our computer and I also put the USB cable from my burner into the computer. You can see the video appear on the screen and it says that the DVD is burning but after over an hour of "burning", I suddenly get an error and it stops. This has happened 3 times. What am I doing wrong?
    President:
  • 2,961 Answers
Your pc may be struggling memory and processor wise especially if you have under 1GB ram fitted, as other applications will be taking u your ram also.
So instead of burning direct to dvd drive burn the dvd image to your hard drive first,(remember about 1 hour of video takes about 10GB of hard drive space) then burn it to dvd, so as your pc is only doing one task at a time
Posted on Aug 21, 2008
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
I have an old Samsung VP-A30 video camera with loads of 8mm tapes, and would like to transfer to either TV/Video/PC. Unfortunately, there seems to be just one AV output source, which feels rather fragile,...
Hello Ron,
Well that is like you say an old camera, mind you 8mm is still far the best and safest way to store your valued films as it has kept the data on those tapes longer than any DVD ever did, remember unlike we thought 10 years ago a DVD only has around 8 to 10 years life span, we are finding CD & DVD productions that are over 8 years old just wont play any longer.
Kodak put a report on the net 7 years ago that they found even some quite costly DVD recorded media had gone blank and refused to play after a very short time in storage.
I think you ought to look around Ebay, find a nice HI8 digital camera, put your loved tapes in that, plug the new Firewire cable into the camera, and your PC and download your treasured items to another media like DVD.
Keep your 8mm tapes in a draw safe though because they will out-live all DVD recordings I can honestly say that.
David
May 24, 2010 | Samsung SC-A30 Camcorder
Crackly sound when recording vhs tape to disc
try new cables going from the vcr to the video capture (yellow red white)
Dec 01, 2009 | Pinnacle Dazzle DVC-100 DVD Recorder
Hi im using Dazzle Dvd recorder dvc100 i'm trying to get my videos from a 8mm to dvd but the picture freezes is there anything that could help solve this problem thankyou in advance marcus.
you will need to transfer through firewire to get the best results. Cable should be provided with the camera but you may need to install a firewire card in your pc/laptop
Nov 25, 2009 | Pinnacle Dazzle DVD Recorder
Copying home made video from sony Hi8 tapes to Sony DV mini tapes
Sony DCR-HC21 has a multi-AV in, your Hi-8 should have a mini (4 band) to multi AV out. The cable would look like a stereo headphone cable on one end with thre RDA type plugs on the other end; red, white, yellow. The mulit in on the DV would probabaly be the same type connector. Youd have to use a coupler set for the two multi-av cables to bridge video to video and audio to audio. Come out of the Hi8 into the miniDV recorder. You should not need a Dazzle unless you want to transfer to a PC for editing before moving video back to a miniDV tape.
Jul 26, 2009 | Sony DSR-30 Mini DV VCR
My dazzle has compasite cable my old vcr does not what to do?
Pretty common situation. You can either just use one connector (audio) and record it as the left or right. If they are home video - they are most likely mono anyway. If they are stereo takes (purchased movies) - you might consider borrrowing a stereo VCR to provide two channel output. Since everyone is going to Digital - many people are giving away older TVs with built in VCR function. I use Dazzel for this alot - it's handy to have a VCR with a good remote for play, stop, pause and FF and RW.
- Sean
May 25, 2009 | Pinnacle Dazzle DVD Recorder
Pinnacle dazzle dvd recorder
sounds like you need the right software.
you,ll need to find out what format the 8mm is in, and what you want to convert to ?
Try looking on the net for conversion tools or programs.
Also look up video codecs et,c.
Hope this at least a step in the right direction.
Mike @ Compurepair.
Feb 18, 2008 | Computers & Internet
Copying 8mm tapes to dvd
try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Dec 27, 2007 | iLO DVDRH04 DVD Recorder
DCV-TRV460 Tranfer to DVD
Converting analog video, like from Hi-8, 8mm, and VHS to digital video is not as simple as plugging in a cable. If you happen to have a DVD recorder deck, you can burn a disc from the footage directly. Otherwise, you'll need to get some sort of capture device that converts the analog information to digital, then burn a DVD. I use a Hauppauge TV capture card, it converts signals from coaxial cable to digital on my hard drive. There are small, USB-based video capture devices readily available, some come with editing software, but you can always use Windows Movie Maker on a PC, or iMovie on a Mac.
Nov 19, 2007 | Video Cameras
Transferring to DVD?
Maybe when you play the 8mm tape on the TV and have DVD/TV recorder hook up to the TV.
Oct 23, 2007 | Sharp Viewcam VL-A111U Camcorder
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
