Question about Weather King 10AJA4201AH Air Conditioner
Weather king model 10AJA4201
Unit is shutting down - next day the unit will start an cool down for several hours then it will stop again. Blower fan will not even come on and outside unit fan stops. There is no problem wth power-all breaker have been checked.
    Scholar:
  • 80 Answers
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Posted on Aug 29, 2010
SOURCE:
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Why is my Weather King A/C Model #10AJA4201 not cooling house? Fan blows warm air. What is problem?
check the outside unit to see if it is running. If its not check the run cap which is the big silver round object. Make sure you are getting 240 volts to the contactor;
Sep 13, 2014 | Weather King Heating & Cooling
I have a Weather King Heat Pump Outdoor Unit, Model 10PJA3101. I noticed that the a/c was on and working fine inside but the fan was NOT moving on the outdoor unit. There are no tripped breakers or...
If you are cool inside and the fan is not running then you are ok... I would however turn the temps. up a bit to eliminate more stress then necessary...
I am surprised that the fan is not working and you are still cooling though.
Was it a windy day? on a still day it may not work...
Are you sure the compressor was running but the fan not???
Some outdoor units do have switches that will turn off the fan if the head pressures are too low if the air temps. are low...
heatman101
Jul 06, 2011 | Weather King 10AJA2501AH Air Conditioner
Not cooling
1st thing to check after you have turned on the unit for say 45 minutes is the larger line coming out of the house to the outside condensing unit. If that line is not sweating on a 40% or higher humid day, your unit is not fully charged with refrigerant, keep in mind also that your outside unit must be able to move air through the coil. If the coil is dirty, turn off the outside electrical box, and wash it down with your water hose till it sparkles, then wait until it drys, turn on the power, and check the large copper line, this line must sweat, if not, the unit is low on refrigerant, and must be charged by a serviceman
Jun 23, 2009 | Weather King 10AJA4201AH Air Conditioner
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Weather king Aj3601
sounds like you have a freon leak hence the smel of oil and fog the unit runs because it has a low pressure cut out to protect the compressor when the pressure builds up enought to close this switch the unit runs as thwe pressure drops the switch cut off you will need to have a leak test done on the Evaprator coil inside
May 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Weather King 10AJA4201AH Air Conditioner Logo
503 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
acrman404a
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
