Question about Akai LCT2721AD 27 in. LCD Television
Wont power up via remote
Just recieved from ebay. remote has fresh batteries. No good. Works from manual controls fine. Could there be a safety code or procedure that locks remote? Tried Direct TV Universal remote- No good.
    Genius:
  • 1,139 Answers
Hello aadams64,
The photo diode might be defective in this TV. I would suggest that you get a schematic and voltmeter to measure the bias voltages and the signals involved in the use of the IR control. This will let you know if the control is working. I would suggest that you get a qualified TV technician to look at your set and troubleshoot it because of the possibility of damage that may occur if you should make a mistake while trying to troubleshoot the problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 21, 2008
SOURCE:
I have a Sony theater reciever that I bought off eBay with no remote. So I looked around and Sears was selling a Sony Universal remote RM-VZ220 saying it was compatible with my Sony STR-K670P AM/FM...
1. Make sure you have good batteries in the remote and they are installed properly.
2. Press the DVD button on the second row of the remote, then check if the Power and other buttons on the remote work with your system (it probably won't since the factory setting is for a Sony DVD player, not a home theater system).
3. If it doesn't work you need to find the correct code number for your system and enter it into the remote. Press and hold the SET button for more than 3 seconds until the SET indicator lights up. Keep holding the SET button down and press the DVD button, then release both buttons. Then enter the code 31622. If you have done this correctly the SET indicator flashes 3 times, if not start over.
4. See if the remote now controls the theater system correctly. If not, repeat the above procedure #3 with the following codes one at a time until you find one that works: 31558, 31658, 31758, 31822, 31858, 32522.
May 23, 2014 | Audio Players & Recorders
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Reciever shuts down by itself
Hi, i have similar/same problem, on initial power on, you have after 3 -4 secs an audible click from inside and all is good... if you then try to change inputs either via front panel and or remote, the unit switches off. if you change input prior to audible click, ie within 2-3 secs of power on , all is good and amp works fine, until you change input etc...very painful fault.. i thought it is sensing /checking the speaker outputs and detecting short etc ,so powering off to protect.. but then just my thought, i suspect something else, if anyone has the fix and can repair , please let me know.
Dec 24, 2009 | Yamaha RX-V800 Receiver
I have an Emerson jumbo universal remote control but i don't have a manual. i need codes to program a Sharp TV and a RCA satelite reciever. help
ok,
Emerson user guides + manuals:
http://tv.manualsonline.com/manuals/mfg/emerson/emerson_universal_remote_product_list.html
...yahoo answers had this (+ related links):
http://answers.yahoo.com/question/index?qid=20090928154252AAElcYI
...our guys had this:
http://www.fixya.com/support/t349346-emerson_jumbo_universal_remote_directv
...and blurtit had this:
http://www.blurtit.com/q160139.html
Remember the older stuff sometimes "will mess up after extended use
..dirt issues, and low battery voltages". Wipe the pushbuttons and use
very fresh batteries on any set that won't properly perform.
WW [email protected]
Oct 04, 2009 | Emerson Televison & Video
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Captive Works CW- 800 S REMOTE CONTROL
for some remotes you press and hold PWR + SET for 5 seconds and that's it.
Mar 31, 2008 | Sony Playstation 3 (PS3) Console
Lost instructions
This solution works for both TARGUS MODEL: AMP01EU and AMP01US (AMP01U AMPolu AMPolEU)
1. Connect the TARGUS reciever to the USB port on your PC.
2. Let it install 'the human interface thing...'
3. Reboot the PC (Windows 2000 and Windows XP)
4. Put fresh batteries in the handheld trackball thing (=the remote)
5. Switch the power switch on the handheld remote from OFF to ON
6. Verify that the green LED is now alive
7. On the reciever press the little button besides the enlightened RED LED to turn it off.
8. On the remote - PUSH the little hidden button on the bottom between the LASER pushbutton and the battery cover multiple times until the RED led on the reciver turns on again. (= We have now connection!)
9. SHAKE mechanichally the remote, so you hear some clicking noise from the remote.
10. Verify that the mouse cursor on the PC screen now can be controlled from the remote.
Please post here if it works or not for you.
A shorter version:
Turn the REMOTE ON
SHAKE IT FORCEFULLY
DONE.
Jul 31, 2007 | Targus AMP01US Remote Control
Akai LCT2721AD 27 in. LCD Television Logo
55 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
