Computer don't show icon for external hard drive when plugged in, but you can hear the computer reconize it when you plug it in.
    President:
  • 2,961 Answers
Right click on my computer desktop icon and select manage, you will be able to see the hard drive present in the listing and set it up, if not there is enough power to power it up but not enough to recognise the hardware, try a different usb port, it may be in a usb1.1 and it will need usb2.0 to work correctly
Posted on Aug 21, 2008
6ya staff
SOURCE:
Why wont my wd media player reconize my tashiba external drive
check whether the folder of you wd hard drive are hidden
Feb 03, 2013 | Computers & Internet
I have toshiba external hard drive but when i plug it my laptop wont work anymore it will hang.
Hi
i would go to your device manager
then go to the top of that box and hover over the icons on the top right
one of those icons will say scan for new hardware
so hit the scan icon
windows may or maynot reconize the external hard drive
then leaving the external drive plugged into the usb
restart the laptop and maybe windows will then reconize it
if not please come back to us again stating what operating system you have
many thanks
Mar 06, 2011 | Computers & Internet
My external hard dirve turns on when i plug it in, but i hear about three-four beeps then it stops but the hard drive is not reconized by the computer.
YOur harddisk can no longer work kindly get another ..
this problem is usally caused by UNsafe shtdown oof the harddisk or when the harddisk falls
Jan 01, 2011 | Computers & Internet
Wont reconize
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have 2 lacie external hard drives that no longer work. They power up and I can hear it working, but they are not reconized on any computer.
Chances are, the IDE/SATA to USB/Firewire controller inside the device has died. You can take the case apart and take the hard drive out, and plug it directly into a computer through IDE or SATA, whichever it is. If the drive is recognized, then all you need is another external case to put the drive into. If it isn't recognized then most likely the powerboard on the hard drive or some other internal mechanical part is dead, and you would need professional data recovery to get anything off of it that you would want.
Apr 30, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
My external hdd used to be reconized and accessable by my computer but after several uses all it does is make a buzzing sound. My computer will not reconize its presence until after it is shut down.
Hi
Its not a software issue with your computer or external hard drive but a hardware issue with the external hard drive. You'll need to get your Iomega hardrive checked from Imomega, hope its under warranty. You can reach them at--
External Hard drive iomega support
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
SimpleTech not reconize by my computer.
hi there,
i will pass on what was given to me for information. if you are still getting power to the drive you can remove the external casing, remove your pc side panel, where you would insert memory and plug the hard drive into the tape inside your pc to see if the pc will recognize the hard drive. if you are not getting any power or platters spinning then it is more serious. i wish you all the best. cherie
Mar 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
External hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Dec 08, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Computers & Internet Logo
Ekse
Marvin
Marvin
