Tomtom GO 300 GPS Receiver Logo
Posted on Aug 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not turn on but have green light - Tomtom GO 300 GPS Receiver
  • 1 more comment
  • goofy94 Sep 17, 2008
    hi I have a Tomtom 910 . the problem i have is the green light in the front is on but the screen is off. it stays off even when i press the on button on top. is it a problem with the screen....
  • Gary Kemp Oct 23, 2008
    Same problem except on the GO 300. Where can I find the IC's and can you give instructions on how to dis-assemble the unit for replacement?
    I have the same problem on my GO 300. Can anyone identify the IC's I need, Where to find them, and how to disassemble the unit for replacement? I've searched all over Tom Tom support net, and they just don't offer any info or help on this issue ( That I was able to find). Any info is appreciated.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
142
Points
No solution so far
  • Anonymous Oct 12, 2008
    how do i fix the 2 IC's blown inside
Anonymous
Level 1:
  • Posted on Oct 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
142
Points
How do i fix the 2 IC's blown inside
A
Anonymous
Try taking your memory card out before trying to switch on and see if it boots from its internal stuff
there is also the fairly well hidden reset button - make sure you know where it is before sticking paper clips in it though!
Anonymous
Level 2:
Novelist:
  • Expert 158 Answers
  • Posted on Sep 13, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
158
Questions
Helped
115394
Points
250
Try resetting it by inserting a small pin or paper clip through the reset hole ( look underneath the tomtom ). if it wont reset then it's likely 2 IC's have blown inside ... U24 and U25.
  • Anonymous Nov 15, 2008
    The 2 IC's are tiny . Any repair has to be conducted by someone who has experience of this sort of thing and also has the correct tools. Normal soldering methods will not work as the IC's are extremely small and the 10 pins on them are very very small and very very close together. If a normal electronics engineers were to try and replace these IC's it's likely they would make things worse. Also just removing the damaged IC's is very delicate and if great care isn't taken then damage can result to the circuit board making any repair impossible. My advice is let someone take a look who is a known repairer of TomToms.
    Take a look here to see a board out of a TomTom , and see the IC's and look at the pins and see how tiny and close together they are . For reference , the hole you see in the circuit board with a gold band round it, takes a 2mm screw so you can guage the size of the IC's . Click this >>>>>>>>
    Click ME
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • 0helpful
    Green light blinking but won t turn
    What green light. You need to give more specifics. If it's a green light on a PC board in the furnace, most blink a heart beat, no problem.
    Is not working more
    1helpful
    2answers
    Does the green light come on after freezer is turned back on?
    if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
    Jan 23, 2013 • Freezers
    1helpful
    I have a 42" Maxent plasma tv. When turned on,
    one or your tv mainboard was crashed, change it with new one
    2helpful
    3answers
    Tv won't turn on. It blinks green then red.
    Question shows tv is Sony KDF-60WF655.
    Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
    Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
    Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
    Did you replaced its lamp in last 2-3 years?
    Thanks.
    When heater first turned on light is green then turns red
    Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
    Cheers
    3helpful
    2answers
    Should the power light be green or red, when I turn camera on it shows a green light then turns red
    Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
    You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
    2answers
    Mitsubishi Medallion does this
    hi there,
    Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
    `jack
    Top Tomtom GPS Experts
    k24674
    Mike Cairns
    Mike Cairns
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
