SOURCE: Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
SOURCE: Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
SOURCE: I have a side by side Maytag Refrigerator model
We had this model as well. It is part of the fridges 'defrost system' that prevents icing up in the freezer. I had replaced the computer chip in mine (at a cost of about 150 bucks), when at one point when it failed, and the freezer starting freezing over, and after it was 'fixed', it started leaking water onto the floor again. After another year, we finally bought another fridge. Solution... buy another fridge
