Question about Motorola Mobility A1000
Phone switches off when charging using car charger
Basically the phone appears to switch off when I plug it into my car charger and havent a clue why?
  • 1 more comment
  • ss90292 Oct 20, 2008
    Mine switches off even when charging with regular charger!!
  • Anonymous Dec 19, 2008
    phone switches off when charging using car charger or home charger
  • timdral Mar 20, 2009
    Phone switches off when charging using wall charger
The phone appears to switch off when I plug it into my charger and restart again show only charging message havent a clue why,plz help me on this matter. thanks
Posted on Nov 10, 2008
Posted on Mar 20, 2009
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
Hi my fridge is warm and there is a build up of condensation on back wall.Also the compressor is hot to touch and takes a while to make any noise once switched off then back on again. Any help would be...
Hot compressor is one of 2 things, Flat charge or the system is plugged up keeping refrigerant from moving. Or the compressor is shot.
If the compressor is staying off for a long time, after running more then likely it has thermal over load protection built in to it (Basically kills power to the compressor, after the compressor reach a certain temp), contact a appliance repairman
Aug 15, 2013 | Hotpoint RLA50 Refrigerator
My w395 sony ericsson phone will not charge i havent used it for a year, how can i fix it?
change the battery.your battery has gone down because of not using it. and even you cannot switch it on by plugging the charger.
Mar 31, 2012 | Sony Ericsson Ericsson Spiro Cell Phone
Phone not switching on
where you plug the charger in on your phone, if you look into it you will be able to see the contacts for it to charge.
on the inner OUTER wall of it ther is 2 pins, use a needle to pull them out a little bit but be carefull not to sanp them.
just so they stick out a little bit, if you do this and the charger dont go in then dont bloody force it in otherwise ya buggered.lol
only when the orange light is on its charging, if you accour a flashing orange light do it again.
this should sort your charge problem.
however you will eventuall need to do it again.
Aug 20, 2009 | HTC P3300 Smartphone
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Charging problem
try to change the battery.........
May 30, 2009 | LG Secret ? KF750 Cellular Phone
Charging phone it went off wont come back on
Remove the battery and clean the contact points. Also plug in the charger and try to switch your phone on. Also notice if the normal charging logo/picture is appearing or not. If the phone does not come ON while plugged in with the charger, then its a problem of the phone. However after cleaning the battery, put it back and try to switch ON without/with the charger and let us know the results............sodeep
May 03, 2009 | LG enV VX9900 Cellular Phone
Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Dec 04, 2008 | LG Secret ? KF750 Cellular Phone
Battery suddenly will not charge.
the charger has gone bad; get a new one at sonyericsson.com
Mar 05, 2008 | Sony Ericsson Z610i Cellular Phone
No power to 6515 even with new fully charged battery to my PDA?
Here's some instructions to fix this :
http://www.123datarecovery.co.uk/fix_ipaq_6515_6915.htm
Photos etc.
It's basically a similar fix for what CTF1800 said but uses paper.
Jan 09, 2008 | HP iPAQ hw6515 Pocket PC
Motorola Mobility A1000 Logo
292 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
