Laptop help my laptop keeps rebooting no screen comes on ubuntu is on hdd. could it be my hdd? it does come on sometimes. seems to be getting hot to. fan is spinning.
  • 94 Answers
Yes, may be the hard drive... so goahead and run a test on hard drive....
try going to bios setup.... from the main menu in bios... highlight the hard drive... maybe displayed in first drive, or second drive...push Enter... and from the list select an option smart self test...
There would be two test's one is smart self test and smart extented self test... first select the smart self test... it would go up to 5 min... if it is pass go to second test...ie., smart extended test...it would go upto an hour.
If first test fails... no need to run the second...directly replace the hdd... but if pass go to second.. and check the hard drive..
As you said you are using UBUNTU.... try install it again.. if hdd both test pass..
Posted on Aug 22, 2008
I cannot get Ubuntu to load onto my Vaio PCV-RZ10. I have already partitioned the HDD with 30 Gig, loaded the OS (Ubuntu) I get a (Not Support) error message. Any ideas?
The problem is your computer is not compatable to run the Ubuntu operational system, it comes up not supported. But you can go online to forums that deal with these types of problems, because there are a lot of people out there that swear by this system.
Mar 10, 2012 | Sony VAIO Digital Studio PCV-RZ10 PC...
My FUJITSU SIEMENS AMILO PA 1538 screen comes black ? HELP
Try connecting the laptop to an external monitor and see if all is working Ok with that, if it is, then you may need to get the laptop display serviced - if it does the same on the external display, then try booting the laptop from a CD or DVD such as an OS install CD (Windows or Linux) or a boot utility CD such as Hiren's Boot CD - this will allow you to test whether the problem lays with your installed operating system or with the hardware. . . .
Note: do not go any further than the initial displays if using an OS install CD unless you are using a Linux Live boot CD which will not destroy your installed operating system. . . .See http://www.hirensbootcd.org/ to download a copy of Hiren's Boot CD to burn to a CD. . . .See http://www.ubuntu.com/download/ubuntu/download to download a copy of a Ubuntu (Linux) Live CD.
Dec 17, 2011 | Computers & Internet
When trying to turn on keep getting message to insert boot disk. it says no bootable device. When I bought the laptop did not come with any disk
It is asking for a boot disk because there is currently no disk available to boot from. This doesn't necessarily need to be a disk that came with the laptop, but you will need to install an operating system such as Windows, Mac OS, or Linux. For a free operating system, I recommend Ubuntu. http://www.ubuntu.com/
Aug 21, 2011 | Computers & Internet
Hp dv9208nr with vist sp2, system keeps rebooting, screen stays blank, cant even get to bios
hi,
When the files in your system are corrupted, your HP laptop would reboot automatically. When the files which are required to run the Operating System like fonts under Windows FONTS directory are been smashed then your system's Operating System will force your HP Laptops to restart continuously. Thus in such a situation you would have to change the name FONTS in the Windows directory.
Get more help to fix HP Laptop Keeps Rebooting error . Hope this helps you.
Apr 24, 2011 | HP Pavilion dv9000z Notebook
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Dell Latitude D410 - OS won't boot only after a few minutes
Seeing that both OS's (Windows XP and Ubuntu) are having a problem booting up, I also think the problem is with your HDD. I think you have a pretty good idea about computers from your use of terms :) There may be some corruption with the HDD. I would check that out first.
Good luck with your problem and thanks for using FixYa.com!!
Apr 18, 2010 | Dell Latitude D410 Notebook
Laptop won't boot. No splash screen. Crash
Take out any USB device from the PC when rebooting: some BIOSes will incorrectly try to boot off them.
If that doesn't work, enter the BIOS Setup (F2 or Del key at boot) and find the Boot Devices menu, confirm that the highest-priority one is "Internal HDD" (or the name of your internal hard disk).
Nov 07, 2009 | Acer Aspire 5670 Notebook
Laptop LCD Screen won't come on and computer keeps rebooting
Try checking the inverter, if that is intermittent, it could short the system and cause the symptoms you are describing.
Apr 03, 2009 | Gateway 7330GZ Notebook
Display andLCD problem
Reboot the sys and go to the bios screen. Change settings back to default and reboot.
Dec 11, 2008 | Dell Inspiron B130 Notebook
Help to start please
It's possible the power cord is defective only giving enough power for a partial boot. I would try another power cord.
If it's not the powercord then it would definitely be the motherboard not taking the power and distributing it correctly and you would have to replace it.
Sep 06, 2008 | Compaq Presario Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
